Up to 20% off select tools
Fellowes T7CM Shaft Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
89
All Time:
2,047
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide shows the removal of the shafts in the Fellowes T7CM.
    1. Fellowes T7CM Shaft Replacement, Fellowes T7CM Casing and Trigger Replacement: step 1, image 1 of 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      Ask FixBot
    2. Fellowes T7CM Shaft Replacement: step 2, image 1 of 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      Ask FixBot
    3. Fellowes T7CM Shaft Replacement: step 3, image 1 of 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      Ask FixBot
    4. Fellowes T7CM Shaft Replacement: step 4, image 1 of 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      Ask FixBot
    1. Fellowes T7CM Shaft Replacement, Gear and Shaft: step 5, image 1 of 2 Fellowes T7CM Shaft Replacement, Gear and Shaft: step 5, image 2 of 2
      • Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
      • Remove the internal case.
      Ask FixBot
    2. Fellowes T7CM Shaft Replacement: step 6, image 1 of 1
      • Remove the feeding sensor by unscrewing the single screw holding it. The screw length is 10 mm and the head diameter is 6 mm.
      • This step may be unnecessary, but it will prevent the sensor from being damaged.
      Ask FixBot
    3. Fellowes T7CM Shaft Replacement: step 7, image 1 of 2 Fellowes T7CM Shaft Replacement: step 7, image 2 of 2
      • Remove the six screws on the gearbox.
      • Remove the gearbox cover to expose the gears.
      • The screw length is 34 mm and the head diameter is 7 mm.
      • The screw length is 26 mm and the head diameter is 7 mm.
      Ask FixBot
    4. Fellowes T7CM Shaft Replacement: step 8, image 1 of 3 Fellowes T7CM Shaft Replacement: step 8, image 2 of 3 Fellowes T7CM Shaft Replacement: step 8, image 3 of 3
      • Remove the gears.
      • The larger gear located in the middle may require a screwdriver to pry off.
      • Remove the gear holder by unscrewing two screws that are holding it in place. The screw length is 14 mm and the head diameter is 5 mm.
      Ask FixBot
    5. Fellowes T7CM Shaft Replacement: step 9, image 1 of 2 Fellowes T7CM Shaft Replacement: step 9, image 2 of 2
      • Remove the pin in order to pull the casing off of the shafts.
      • Remove the casing in order to expose shafts.
      Ask FixBot
    1. Fellowes T7CM Shaft Replacement, Shaft: step 10, image 1 of 1
      • Remove the metal attachment that holds the two shafts together.
      Ask FixBot
    2. Fellowes T7CM Shaft Replacement: step 11, image 1 of 1
      • The shafts can now be pulled apart and any obstructions located between or on each of the shafts can be removed.
      Ask FixBot
3 other people completed this guide.
Author
with
Michael Aldrich
686 Reputation
5 Guides authored
IUPUI, Team 2-2, Baechle Fall 2016 Member of IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 89
All Time: 2,047
