Up to 20% off select tools
Faucet Stem Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
9
Past 7 Days:
79
Past 30 Days:
352
All Time:
3,446
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this guide, I'll walk you through replacing a leaking faucet stem for a Delta water faucet. Don't worry, it's easier than it sounds! We'll cover it in about 10-11 simple steps, using only three common household tools and a brand new faucet stem. Let's get started!
    1. Faucet Stem Replacement, Stem: step 1, image 1 of 1
      • Turn off the water supply.
      Ask FixBot
    2. Faucet Stem Replacement: step 2, image 1 of 1
      • Pry off the faucet cap with a spudger.
      Ask FixBot
    3. Faucet Stem Replacement: step 3, image 1 of 1
      • Unscrew the knob with either a Phillips or a flathead screwdriver, depending on your faucet.
      • Remove the knob from the faucet.
      Ask FixBot
    4. Faucet Stem Replacement: step 4, image 1 of 1
      • Use a wrench to remove the nut from the faucet stem.
      Ask FixBot
    5. Faucet Stem Replacement: step 5, image 1 of 1
      • Remove the faucet stem using pliers.
      • Removing the stem can be very difficult so make sure you are stable and have control.
      Ask FixBot
    6. Faucet Stem Replacement: step 6, image 1 of 1
      • Use a paper towel to soak up any excess water in the area where the stem was located.
      Ask FixBot
    7. Faucet Stem Replacement: step 7, image 1 of 1
      • To replace the new stem, simply push it down into the hole.
      Ask FixBot
    8. Faucet Stem Replacement: step 8, image 1 of 2 Faucet Stem Replacement: step 8, image 2 of 2
      • When the stem is installed, screw in the nut over the stem with pliers.
      Ask FixBot
    9. Faucet Stem Replacement: step 9, image 1 of 1
      • Apply the knob and screw into the stem.
      Ask FixBot
    10. Faucet Stem Replacement: step 10, image 1 of 1
      • Lastly, Turn the water supply back on and watch the magic happen!
      Ask FixBot
I hope this guide was simple and easy to follow. If you have any questions, feel free to leave a comment below, and I'll get back to you as soon as possible.
4 other people completed this guide.
Author
with
Tristan Norris
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 79
Past 30 Days: 352
All Time: 3,446
