Up to 20% off select tools
Faucet Aerator Replacement
Views: 7.6K
View statistics:
Past 24 Hours:
21
Past 7 Days:
126
Past 30 Days:
609
All Time:
7,604
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 7 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
A faucet aerator is a small yet significant fixture in your kitchen or bathroom sink that helps to control the water flow, reduce splashing, and conserve water. Over time, these aerators can become clogged or damaged, leading to issues like low water pressure or inconsistent water flow. If you're experiencing such problems, it may be time to replace your faucet aerator.
In this guide, we'll walk you through the step-by-step process of replacing a faucet aerator. Our guide will help you tackle this simple and satisfying task with confidence.
So let's get started!
    1. Faucet Aerator Replacement, Aerator: step 1, image 1 of 2 Faucet Aerator Replacement, Aerator: step 1, image 2 of 2
      • To shut off the water supply to the sink, rotate the valve in a clockwise direction until it stops.
      Ask FixBot
    2. Faucet Aerator Replacement: step 2, image 1 of 2 Faucet Aerator Replacement: step 2, image 2 of 2
      • To remove the aerator, use an adjustable wrench to rotate it in a clockwise direction until it is loosened.
      Ask FixBot
    3. Faucet Aerator Replacement: step 3, image 1 of 2 Faucet Aerator Replacement: step 3, image 2 of 2
      • To ensure a smooth installation, clean the threads on the faucet to eliminate any dirt or debris.
      Ask FixBot
    4. Faucet Aerator Replacement: step 4, image 1 of 3 Faucet Aerator Replacement: step 4, image 2 of 3 Faucet Aerator Replacement: step 4, image 3 of 3
      • Carefully insert the new aerator into the collar, making sure that the mesh end is facing downward. Push the aerator firmly into the collar to ensure a tight fit.
      • Place the aerator gasket on top of the aerator within the faucet collar. This will create a seal between the aerator and the faucet, preventing any water from leaking out.
      • Use your fingers to tighten the faucet collar and aerator onto the end of the faucet.
      • Make sure it is tightened securely, but not too tightly to avoid damaging the threads.
      Ask FixBot
    5. Faucet Aerator Replacement: step 5, image 1 of 2 Faucet Aerator Replacement: step 5, image 2 of 2
      • Turn the water supply valve counterclockwise until it is fully opened.
      Ask FixBot
    6. Faucet Aerator Replacement: step 6, image 1 of 1
      • Check that the aerator is properly installed and securely attached to the faucet
      Ask FixBot
To summarise, changing the faucet aerator is an easy and affordable solution to increase water flow and save water in your kitchen or bathroom sink. You can quickly determine the type of aerator you have, choose the proper replacement component, and install it correctly by following the step-by-step procedure described in this article.
We really hope that this guild has been useful in assisting you as you replace a faucet aerator. Feel free to contact a plumbing expert for advice if you have any questions or concerns.
Good luck! Thank you for reading!
2 other people completed this guide.
Author
with
Yousuf Mohamed
148 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 21
Past 7 Days: 126
Past 30 Days: 609
All Time: 7,604
