Up to 20% off select tools
Fast Fix Screen Replacement
Views: 4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
100
All Time:
4,012
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide can be used to remove and replace a screen on a Dell Insprion 15-3521. The tools needed are a small Phillips screwdriver, and a small flat screwdriver or like prying device.
    1. Fast Fix Screen Replacement, Screen: step 1, image 1 of 3 Fast Fix Screen Replacement, Screen: step 1, image 2 of 3 Fast Fix Screen Replacement, Screen: step 1, image 3 of 3
      • Slide both battery latches to release cover.
      • Remove battery.
      Ask FixBot
    2. Fast Fix Screen Replacement: step 2, image 1 of 2 Fast Fix Screen Replacement: step 2, image 2 of 2
      • Remove the M2.5 X 5mm phillips screw for the CD drive.
      • Remove the CD drive.
      Ask FixBot
    3. Fast Fix Screen Replacement: step 3, image 1 of 2 Fast Fix Screen Replacement: step 3, image 2 of 2
      • Loosen 2 screws on access door.
      • They cannot be removed
      • Remove the access door.
      Ask FixBot
    4. Fast Fix Screen Replacement: step 4, image 1 of 1
      • Remove 12 M2.5 X 5MM Phillips bottom palm rest screws.
      Ask FixBot
    5. Fast Fix Screen Replacement: step 5, image 1 of 3 Fast Fix Screen Replacement: step 5, image 2 of 3 Fast Fix Screen Replacement: step 5, image 3 of 3
      • Use a small screwdriver to press in the keyboard latches.
      • Remove the keyboard.
      • Unplug the keyboard cable at the ZIF connection.
      Ask FixBot
    6. Fast Fix Screen Replacement: step 6, image 1 of 3 Fast Fix Screen Replacement: step 6, image 2 of 3 Fast Fix Screen Replacement: step 6, image 3 of 3
      • Remove the palm-rest cable by releasing the ZIF latch and pulling the wire out.
      • Remove 5 M2.5 X 5mm Phillips and 2 M2 X 3mm Phillips palm-rest screws.
      Ask FixBot
    7. Fast Fix Screen Replacement: step 7, image 1 of 1
      • Use a small flat screwdriver to pry the palm-rest off of the computer.
      Ask FixBot
    8. Fast Fix Screen Replacement: step 8, image 1 of 3 Fast Fix Screen Replacement: step 8, image 2 of 3 Fast Fix Screen Replacement: step 8, image 3 of 3
      • Remove the wireless antenna
      • Remove the LCD cable
      Ask FixBot
    9. Fast Fix Screen Replacement: step 9, image 1 of 1
      • Remove the 1 M2.5 x 5mm Phillips left hinge screw and 2 M2.5 x 5mm Phillips right hinge screw.
      Ask FixBot
    10. Fast Fix Screen Replacement: step 10, image 1 of 1
      • Pry off the LCD bevel using a small flat screwdriver.
      Ask FixBot
    11. Fast Fix Screen Replacement: step 11, image 1 of 1
      • Remove the 4 M2 X 3mm Philips LCD screws.
      Ask FixBot
    12. Fast Fix Screen Replacement: step 12, image 1 of 2 Fast Fix Screen Replacement: step 12, image 2 of 2
      • Unplug the screen cable and remove the screen.
      Ask FixBot
5 other people completed this guide.
Author
with
Carl Kangas
236 Reputation
1 Guide authored
2 Guide Comments
Hello good day, I have a question, I have managed to replace the screen and the computer started the first time without problems, but after I started it again the computer did not turn on the screen again, will you have any possible solution?
vikingo1ero - Reply Share
Hi, Did you ever fix this problem? I'm having the same issue.
Chris Terry - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 100
All Time: 4,012
