Up to 20% off select tools
Fast Fix Pool tiles Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
65
All Time:
461
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 12 hours
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Hello there! We are slapping a Fast Fix Guide on iFixit! We hope this guide helps you to fix your pool.
    1. Fast Fix Pool tiles Replacement, Pool tiles: step 1, image 1 of 1
      • Remove enough water from the pool, so you can start working.
      Ask FixBot
    2. Fast Fix Pool tiles Replacement: step 2, image 1 of 1
      • Get a hammer and chisel so you can start working.
      Ask FixBot
    3. Fast Fix Pool tiles Replacement: step 3, image 1 of 1
      • In this step , by using a hammer and a chisel , you must remove all the grout that can be found after removing the old tiles. The flat surface where you will placing your new tiles needs to be clean so that the new tile can be placed properly.
      Ask FixBot
    4. Fast Fix Pool tiles Replacement: step 4, image 1 of 1
      • In this step , you must take mix concrete concentrate and water together. After it has been mixed properly , you should wait 10 minutes so that the mixture can settle down.
      Ask FixBot
    5. Fast Fix Pool tiles Replacement: step 5, image 1 of 1
      • In this step , you must apply the concrete mixture to the back of the new tiles so that it can be later placed at the location where the old tiles were removed.
      Ask FixBot
    6. Fast Fix Pool tiles Replacement: step 6, image 1 of 1
      • Finally, you must wait 8 hours for the tiles to dry up. Once the pool tiles are checked to see if they are dry, you can then proceed to fill the pool up with water.
      Ask FixBot
Your pool is now repaired. You may proceed to swimming.
Author
with
Abhishek Minhas
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 65
All Time: 461
