Fast Fix Fluval Spec V Impeller Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
85
All Time:
1,557
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a faulty impeller in the circulation pump (model P-150) of your Fluval Spec V Aquarium.
The impeller is a crucial component that drives water circulation within your aquarium setup. Over time or due to various factors, the impeller can become damaged, leading to reduced circulation or complete halt, both of which can have negative impacts on the wellbeing of your aquatic life. This guide walks you through the steps of replacing the impeller to restore optimum water circulation.
While this repair does not pose significant hazards, caution is required to ensure the safety of your aquarium's inhabitants, particularly if you have delicate species like Neocaridina shrimps. This guide includes necessary precautions to prevent them from getting stuck inside the filtration compartment during the repair.
You will need a pry tool like a smell flathead screwdriver for this repair, and a pair of needle nose pliers may come in handy. Both are common tools and don't require any special skills to use.
For additional information on maintaining your Fluval Spec V Aquarium, you may refer to the official manual.
Remember to disconnect the aquarium from power before starting the repair to ensure safety. Happy repairing!"
    1. Fast Fix Fluval Spec V Impeller Replacement, Fluval Spec V Impeller: step 1, image 1 of 2 Fast Fix Fluval Spec V Impeller Replacement, Fluval Spec V Impeller: step 1, image 2 of 2
      • Unplug Aquarium: Firmly but carefully unplug it.
      • Never try to perform any maintenance or repair tasks on an aquarium or any other electrical appliance while it is still connected to a power source.
      Ask FixBot
    2. Fast Fix Fluval Spec V Impeller Replacement: step 2, image 1 of 2 Fast Fix Fluval Spec V Impeller Replacement: step 2, image 2 of 2
      • Remove Light: Carefully lift light from its mount, ensuring not to pull on any wires.
      • If the light is connected to a different power source, disconnect it first before removal.
      • Remove Lid Securely grasp edge of the aquarium lid and lift up to remove.
      Ask FixBot
    3. Fast Fix Fluval Spec V Impeller Replacement: step 3, image 1 of 3 Fast Fix Fluval Spec V Impeller Replacement: step 3, image 2 of 3 Fast Fix Fluval Spec V Impeller Replacement: step 3, image 3 of 3
      • Insert Pry Tool: Take a small, flat-head screwdriver or pry tool and carefully insert it between the nozzle and the filter tube.
      • Pry Off Nozzle: Carefully apply some leverage to pry nozzle away from the filter tube. It should gradually detach.
      • Make sure to apply force evenly and gently to avoid breaking the nozzle.
      • Pull Out Filter Tube: Grasp the filter tube firmly and pull it out from the divider.
      • Pull straight sideways for easy removal, this will prevent damaging the tube or the divider.
      • If the tube is firmly stuck, try gently wiggling it as you pull.
      Ask FixBot
    4. Fast Fix Fluval Spec V Impeller Replacement: step 4, image 1 of 2 Fast Fix Fluval Spec V Impeller Replacement: step 4, image 2 of 2
      • Caution: To protect Neocaridina shrimps, nano fish, and other small aquatic creatures in your aquarium, an extra precautionary step is necessary due to the potential danger posed by the outlet leading into the filtration compartment, which could cause them to get stuck behind the divider.
      • Cover Outlet (Optional): Carefully insert a suitable filter medium into the outlet.
      • This could be a piece of sponge, mesh, or any other aquarium-safe material that allows water flow while preventing the shrimps or fish from entering the filtration compartment. Be sure to securely place the filter medium so that it doesn't shift or come loose, potentially leaving the outlet unprotected.
      Ask FixBot
    5. Fast Fix Fluval Spec V Impeller Replacement: step 5, image 1 of 3 Fast Fix Fluval Spec V Impeller Replacement: step 5, image 2 of 3 Fast Fix Fluval Spec V Impeller Replacement: step 5, image 3 of 3
      • Pull Up on Output Tube: Firmly grasp the output tube and pull straight up. The pump should follow along, detaching from the bottom of the aquarium.
      • If you're having trouble removing the pump it may be due to the suction cups at the bottom of the pump securely holding it in place. In this case, try pulling up in a circular pattern. This action can help dislodge the suction cups, making it easier to lift the pump out.
      • Drain Excess Water: Hold pump over the tank for a moment to allow any excess water to drain out of the pump.
      • This will prevent water from spilling and making a mess as you work on the pump.
      Ask FixBot
    6. Fast Fix Fluval Spec V Impeller Replacement: step 6, image 1 of 2 Fast Fix Fluval Spec V Impeller Replacement: step 6, image 2 of 2
      • Insert Pry Tool: Take your small pry tool and carefully insert it anywhere under the edge of the pump cover.
      • Pry Off Cover: Gently pry it off by twisting the tool.
      • Twisting the pry tool will give you a smoother, more controlled prying action and minimize the risk of the cover suddenly popping off or flying away.
      Ask FixBot
    7. Fast Fix Fluval Spec V Impeller Replacement: step 7, image 1 of 2 Fast Fix Fluval Spec V Impeller Replacement: step 7, image 2 of 2
      • Insert Pry Tool: Carefully insert your pry tool anywhere under the edge of this cover.
      • Pry Off Cover: Gently pry it off.
      • Be sure to handle with care to prevent any damage to the impeller assembly underneath.
      Ask FixBot
    8. Fast Fix Fluval Spec V Impeller Replacement: step 8, image 1 of 2 Fast Fix Fluval Spec V Impeller Replacement: step 8, image 2 of 2
      • Grasp Impeller: Get a firm but gentle grip on the impeller.
      • The impeller is inset, making it difficult to grasp by hand. In this case, a pair of needle-nose pliers will come in handy.
      • Pull Out Impeller: Slowly and carefully pull it straight out.
      • Do not to twist or yank the impeller to prevent damage to it or the pump assembly.
      Ask FixBot
    9. Fast Fix Fluval Spec V Impeller Replacement: step 9, image 1 of 1
      • Install New Impeller: Take your new impeller and carefully align the slot with the pin in the impeller housing. Gently slide the new impeller on to the pin, ensuring that it's oriented correctly.
      • The impeller is magnetic, so it will naturally adhere to the motor assembly and does not require any additional securing. Once the impeller is in place, it should spin freely when nudged. This will confirm that it has been installed correctly.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
I’ve been looking everywhere for this info. Thank you!
Shauna - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 85
All Time: 1,557
