Up to 20% off select tools
Fast Fix FOB Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
9
Past 7 Days:
53
Past 30 Days:
234
All Time:
1,675
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace a battery in a car FOB, which is needed to unlock/lock your vehicle and easily access it. There is also a remote start feature on the FOB, so fixing it benefits the user in many ways. Fixing the FOB is safe and easy, there is no safety risk involved. The only requirement for this fix is purchasing new batteries, which can be found in any drug store for a very inexpensive price.
    1. Fast Fix FOB Battery Replacement, Battery: step 1, image 1 of 1
      • Purchase two CR2016 batteries.
      • You can find these at your local drugstore or hardware store.
      Ask FixBot
    2. Fast Fix FOB Battery Replacement: step 2, image 1 of 2 Fast Fix FOB Battery Replacement: step 2, image 2 of 2
      • Use a small and thin object, like a penny or other coin, to pry open the FOB. It will separate into two pieces.
      Ask FixBot
    3. Fast Fix FOB Battery Replacement: step 3, image 1 of 1
      • Identify which part of the FOB holds the battery. You should be able to clearly see the circular batteries in one half.
      • You should be able to clearly see the circular batteries in one half. You will not the need the other part of the FOB until the end.
      Ask FixBot
    4. Fast Fix FOB Battery Replacement: step 4, image 1 of 2 Fast Fix FOB Battery Replacement: step 4, image 2 of 2
      • Remove both batteries from the FOB by releasing them from the prongs.
      Ask FixBot
    5. Fast Fix FOB Battery Replacement: step 5, image 1 of 2 Fast Fix FOB Battery Replacement: step 5, image 2 of 2
      • Insert the new CR2016 batteries with the positive side facing down, and make sure the batteries are secure under the prongs.
      Ask FixBot
    6. Fast Fix FOB Battery Replacement: step 6, image 1 of 3 Fast Fix FOB Battery Replacement: step 6, image 2 of 3 Fast Fix FOB Battery Replacement: step 6, image 3 of 3
      • Put the FOB back together.
      • You should hear a click that secures the two pieces in place.
      Ask FixBot
Finish Line
Author
with
jtorman@udel.edu
196 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 53
Past 30 Days: 234
All Time: 1,675
