Introduction
Go to step 1 ↓If your light is not turning on, then you most likely have a short circuit, which requires a replacement. This guide is specifically meant for incandescent light bulbs under a ceiling mount. It will demonstrate how to remove the broken bulb and replace it with a functional bulb. Make sure there is no current running through the light bulb to avoid electrocution before you begin.
Tools
Turn off the electrical circuit breaker and the light switch.
If the lightbulb does not work after step 7, then you need to get a new lightbulb and repeat step 5-7. If it still does not work then your socket might need a replacement.
