Up to 20% off select tools
Fast Fix Bladwin Lock Privacy Pin Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
39
All Time:
63
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Baldwin doorknobs are common household hardware. Over time, Baldwin locks can damage and wither, leading to the need for repairs and replacements. This guide will showcase how to replace a broken Baldwin lock.
    1. Fast Fix Bladwin Lock Privacy Pin Replacement, Step 1: step 1, image 1 of 3 Fast Fix Bladwin Lock Privacy Pin Replacement, Step 1: step 1, image 2 of 3 Fast Fix Bladwin Lock Privacy Pin Replacement, Step 1: step 1, image 3 of 3
      • Use metric Allan Wrench to remove set screws on knob
      • Set Screws lie within the cylinder of the knob
      • Turn counter clockwise
      Ask FixBot
    2. Fast Fix Bladwin Lock Privacy Pin Replacement, Step 2: step 2, image 1 of 2 Fast Fix Bladwin Lock Privacy Pin Replacement, Step 2: step 2, image 2 of 2
      • Push inner holding pins inward and remove rose cover.
      • Both sides of inner pins must be pushed.
      • Rose cover will pop off.
      Ask FixBot
    3. Fast Fix Bladwin Lock Privacy Pin Replacement, Step 3: step 3, image 1 of 2 Fast Fix Bladwin Lock Privacy Pin Replacement, Step 3: step 3, image 2 of 2
      • Remove screw holding adapters and remove adapters
      • Save screws
      Ask FixBot
    4. Fast Fix Bladwin Lock Privacy Pin Replacement, Step 4: step 4, image 1 of 2 Fast Fix Bladwin Lock Privacy Pin Replacement, Step 4: step 4, image 2 of 2
      • Install new Adapters
      Ask FixBot
    5. Fast Fix Bladwin Lock Privacy Pin Replacement, Step 5: step 5, image 1 of 1
      • Reinstall Rose Cover using wrench provided in repair kit
      • Turn Counter-clockwise till tightened
      Ask FixBot
    6. Fast Fix Bladwin Lock Privacy Pin Replacement, Step 6: step 6, image 1 of 2 Fast Fix Bladwin Lock Privacy Pin Replacement, Step 6: step 6, image 2 of 2
      • Install doorknobs and tighten using Allen wrench & set screws
      • Turn set screws clockwise
      Ask FixBot
Ryan Stewart
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 39
All Time: 63
