Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
95
All Time:
4,364
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Very easy
Introduction
Go to step 1 ↓
This fast fix is to fix the buttons on a 2006 Honda Cr-V key fob. It is a very simple and easy fix. You will only need one tool and the replacement part.
    1. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement, 2006 Honda CR-V Key Fob: step 1, image 1 of 1
      • You will need to take the key off the ring.
      Ask FixBot
    2. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 2, image 1 of 1
      • The second step is to take out the little screw on the back side of the key.
      Ask FixBot
    3. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 3, image 1 of 1
      • Unclip the back part of your key.
      • This part is super fragile.
      Ask FixBot
    4. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 4, image 1 of 1
      • You will push the buttons from the front side to have the middle piece fall out.
      Ask FixBot
    5. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 5, image 1 of 2 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 5, image 2 of 2
      • Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
      Ask FixBot
    6. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 6, image 1 of 2 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 6, image 2 of 2
      • Then push the buttons from the front side to push out a rubber insert.
      Ask FixBot
    7. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: step 7, image 1 of 1
      • Then peel out the mother chip and replace your rubber insert.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Me Me - Reply Share
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 95
All Time: 4,364
