Farberware FSTO100 Power Supply Replacement
    1. Farberware FSTO100 Power Supply Replacement, Power Supply: step 1, image 1 of 1
      • Make sure the toaster is unplugged.
      • First, to remove the plastic bracket, turn toaster oven on its side.
      Ask FixBot
    2. Farberware FSTO100 Power Supply Replacement: step 2, image 1 of 1
      • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
      Ask FixBot
    3. Farberware FSTO100 Power Supply Replacement: step 3, image 1 of 1
      • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
      Ask FixBot
    4. Farberware FSTO100 Power Supply Replacement: step 4, image 1 of 1
      • If the wire gets pulled out of the transformer, reinsert it.
      • Use a small flathead screwdriver to secure the screw that holds the wire in place.
      Ask FixBot
Tony Wang
112 Reputation
5 Guides authored
Cal Poly, Team 6-35, Regan Fall 2012 Member of Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,828
