Farberware FSTO100 Heating Mechanism Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
109
All Time:
2,389
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
If your Farberware FSTO100 toaster oven has stopped heating up your food, Then use this guide to replace your heating mechanism. Toaster ovens use lead wires to transmit heat from the generator to the heating mechanism. Broken or unscrewed wires can lead to faulty or no heating at all.
Be cautious when working with this mechanism and always make sure to unplug the toaster before starting.
Before starting this repair check under the toaster to see if your wires are either are not connected or broken.
Tools
    1. Farberware FSTO100 Heating Mechanism Replacement, Heating Mechanism: step 1, image 1 of 1
      • remove the screw at its original attachment point.
      • Check if the lead wire is broken
      Ask FixBot
    2. Farberware FSTO100 Heating Mechanism Replacement: step 2, image 1 of 1
      • Make sure that the lead is attached and in contact.
      Ask FixBot
    3. Farberware FSTO100 Heating Mechanism Replacement: step 3, image 1 of 1
      • Retighten screw to secure lead.
      Ask FixBot
Tony Wang
112 Reputation
5 Guides authored
Cal Poly, Team 6-35, Regan Fall 2012 Member of Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 109
All Time: 2,389
