Up to 20% off select tools
Fan Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
131
All Time:
1,397
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Fan Replacement
Tools
    1. Fan Replacement, Fan/Heat Sink: step 1, image 1 of 1
      • Remove all the screws that hold the plastic bottom cover on. There are some more screws that cant be seen in the photo.
      Ask FixBot
    2. Fan Replacement: step 2, image 1 of 1
      • Once screws are removed, remove the back cover.
      Ask FixBot
    3. Fan Replacement: step 3, image 1 of 1
      • Encased in red is the area where we are working on
      Ask FixBot
    4. Fan Replacement: step 4, image 1 of 2 Fan Replacement: step 4, image 2 of 2
      • Locate the two strips of cables projecting from the fan to the white holders circled in red.
      • Using your hand carefully remove the two strips of cables from the white sockets. Preferably grabbing the strip by the head(the white section where the cables are engulfed). If unable to gingerly pull on the cables.
      • Make care to not rip the connectors and the cables
      Ask FixBot
    5. Fan Replacement: step 5, image 1 of 1
      • Unscrew the four screws surrounding the heat sink.
      Ask FixBot
    6. Fan Replacement: step 6, image 1 of 1
      • You are now clear for liftoff. The fan may fly freely.
      • Now is a prime time to reapply thermal paste if necessary.
      Ask FixBot
Author
with
Eric Martinez
667 Reputation
6 Guides authored
USF Tampa, Team 20-5, Remmell Spring 2017 Member of USF Tampa, Team 20-5, Remmell Spring 2017
USFT-REMMELL-S17S20G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 131
All Time: 1,397
