Up to 20% off select tools
Fan Coil Filter Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
122
All Time:
1,744
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
It is not common knowledge to replace the filter in a fan coil system despite the fact that it may seem so to others. This guide will ensure that you are able to replace the existing filter in your fan coil system in a quick and effective manner. People will spend money to have someone come in and repair their fan coil due to damage caused by dust and residue build-up on the filter. Meanwhile, this damage can be avoided altogether by regular filter changes. A fan coil filter should be replaced every 2-3 months to ensure clean air quality in the household.
    1. Fan Coil Filter Replacement, Fan Coil Filter Replacement: step 1, image 1 of 1
      • Clean the fan coil grilles using a paper towel and water.
      • Ensure that the register is thoroughly cleaned out before starting the filter replacement process.
      Ask FixBot
    2. Fan Coil Filter Replacement: step 2, image 1 of 1
      • Close off each adjustable damper.
      • This will ensure that the register grille does not get in the way later on during the filter removal.
      Ask FixBot
    3. Fan Coil Filter Replacement: step 3, image 1 of 2 Fan Coil Filter Replacement: step 3, image 2 of 2
      • Remove the screws from fan coil using a Phillips #1 screwdriver.
      • Open up the fan coil.
      Ask FixBot
    4. Fan Coil Filter Replacement: step 4, image 1 of 1
      • Use your hands to remove the filter from the fan coil.
      Ask FixBot
    5. Fan Coil Filter Replacement: step 5, image 1 of 2 Fan Coil Filter Replacement: step 5, image 2 of 2
      • Replace the fan coil filter.
      • Make sure to close the fan coil door after the filter replacement is completed.
      Ask FixBot
    6. Fan Coil Filter Replacement: step 6, image 1 of 2 Fan Coil Filter Replacement: step 6, image 2 of 2
      • Screw in closed the fan coil door.
      • Open up each of the adjustable dampers for better air flow.
      Ask FixBot
Following these steps, you will be able to replace the filter in your fan coil system.
Author
with
Abukar Ahmed
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 122
All Time: 1,744
