Up to 20% off select tools
Fan Blade Arm Replacement
Views: 9.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
118
All Time:
9,899
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the broken blade arm of a ceiling fan. A broken ceiling fan can reduce the comfort of your home, and it might make you utilize your home’s air conditioner (AC) more. A working ceiling fan will save money and potentially reduce greenhouse gases that hurt the earth.
Before using this guide, make sure you know where the circuit breaker is located and turn it off for safety reasons. A few necessary tools are needed, and no prior knowledge is required.
    1. Fan Blade Arm Replacement, Fan Blade Arm: step 1, image 1 of 3 Fan Blade Arm Replacement, Fan Blade Arm: step 1, image 2 of 3 Fan Blade Arm Replacement, Fan Blade Arm: step 1, image 3 of 3
      • Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
      Ask FixBot
    2. Fan Blade Arm Replacement: step 2, image 1 of 2 Fan Blade Arm Replacement: step 2, image 2 of 2
      • Unscrew the finial (cover at the bottom of the glass globe). Then unscrew the hex nut and remove the rubber washer. This will allow the globe to be easily removed.
      Ask FixBot
    3. Fan Blade Arm Replacement: step 3, image 1 of 3 Fan Blade Arm Replacement: step 3, image 2 of 3 Fan Blade Arm Replacement: step 3, image 3 of 3
      • Remove lightbulbs to avoid damage when removing light pan. Then, remove all three fitter plate screws. This will cause the light pan to hang from the electrical wires.
      Ask FixBot
    4. Fan Blade Arm Replacement: step 4, image 1 of 2 Fan Blade Arm Replacement: step 4, image 2 of 2
      • Disconnect single pin connectors to finish removing light fixture from fan.
      Ask FixBot
    5. Fan Blade Arm Replacement: step 5, image 1 of 2 Fan Blade Arm Replacement: step 5, image 2 of 2
      • Remove the three screws from the fitter plate. This will allow the plate to easily be separated from the fan.
      Ask FixBot
    6. Fan Blade Arm Replacement: step 6, image 1 of 3 Fan Blade Arm Replacement: step 6, image 2 of 3 Fan Blade Arm Replacement: step 6, image 3 of 3
      • Remove the two screws securing the broken blade arm. Then separate the broken component from the fan.
      Ask FixBot
    7. Fan Blade Arm Replacement: step 7, image 1 of 3 Fan Blade Arm Replacement: step 7, image 2 of 3 Fan Blade Arm Replacement: step 7, image 3 of 3
      • Replace the broken blade arm on the fan blade. There are two components that are placed on either side of the blade and secured together with screws.
      Ask FixBot
2 other people completed this guide.
Author
with
Ricardo Ledesma Hernandez
145 Reputation
1 Guide authored
4 Guide Comments
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
Maria Franco - Reply Share
I am as well and harbor breeze and Lowe's are absolutely no help!
Brandy Broussard - Reply Share
I’m looking for the same thing CANT find it anywhere I need the arm
Lisa - Reply Share
Where can I find an exact replacement.
Darrell Resler - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 118
All Time: 9,899
