Up to 20% off select tools
Fairphone SIM Card Replacement
Views: 14K
View statistics:
Past 24 Hours:
3
Past 7 Days:
43
Past 30 Days:
242
All Time:
13,851
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace either, or both, of the two SIM cards, and the microSD card.
    1. Fairphone SIM Card Replacement, Back Cover: step 1, image 1 of 3 Fairphone SIM Card Replacement, Back Cover: step 1, image 2 of 3 Fairphone SIM Card Replacement, Back Cover: step 1, image 3 of 3
      • There is a small indentation in the side of the phone near the bottom of the back cover.
      • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
      Ask FixBot
    2. Fairphone SIM Card Replacement: step 2, image 1 of 3 Fairphone SIM Card Replacement: step 2, image 2 of 3 Fairphone SIM Card Replacement: step 2, image 3 of 3
      • Slide the back cover down and remove it from the phone.
      Ask FixBot
    1. Fairphone SIM Card Replacement, Battery: step 3, image 1 of 3 Fairphone SIM Card Replacement, Battery: step 3, image 2 of 3 Fairphone SIM Card Replacement, Battery: step 3, image 3 of 3
      • There is a small indentation in the back of the phone just below the battery.
      • Use a fingernail in this indentation to push the battery toward the top of the phone
      • Pull the battery out away from the phone.
      Ask FixBot
    2. Fairphone SIM Card Replacement: step 4, image 1 of 1
      • Remove the battery from your Fairphone.
      Ask FixBot
    1. Fairphone SIM Card Replacement, SIM and MicroSD Card: step 5, image 1 of 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: step 5, image 2 of 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: step 5, image 3 of 3
      • Use your finger to slide the SIM card straight down out of its tray.
      • Remove the SIM card from your Fairphone.
      • Repeat this procedure if you have a second SIM card.
      • Be sure to remove all SIM cards before servicing your phone.
      Ask FixBot
    2. Fairphone SIM Card Replacement: step 6, image 1 of 2 Fairphone SIM Card Replacement: step 6, image 2 of 2
      • If you have a microSD card, use your finger to slide it straight out of its slot.
      • Remove the microSD card from your phone.
      Ask FixBot
Sam Goldheart
478,973 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 242
All Time: 13,851
