Fairphone Fairbuds USB-C Port Replacement
  1. Fairphone Fairbuds USB-C Port Replacement, Remove the earbuds: step 1, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the earbuds: step 1, image 2 of 2
    • Remove your earbuds from the charging case.
    Ask FixBot
  2. Fairphone Fairbuds USB-C Port Replacement, Remove the outer shell screw: step 2, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the outer shell screw: step 2, image 2 of 2
    • Flip your charging case upside down.
    • Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
    Ask FixBot
  3. Fairphone Fairbuds USB-C Port Replacement, Remove the battery: step 3, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the battery: step 3, image 2 of 2
    • Flip up the bottom of the outer shell to expose the battery.
    Ask FixBot
  4. Fairphone Fairbuds USB-C Port Replacement: step 4, image 1 of 3 Fairphone Fairbuds USB-C Port Replacement: step 4, image 2 of 3 Fairphone Fairbuds USB-C Port Replacement: step 4, image 3 of 3
    • Use your finger to pry up the battery at its notch and remove it.
    Ask FixBot
  5. Fairphone Fairbuds USB-C Port Replacement, Remove the charging core: step 5, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the charging core: step 5, image 2 of 2
    • Lift the charging core out of the outer shell and remove it.
    Ask FixBot
  6. Fairphone Fairbuds USB-C Port Replacement, Remove the charging core screws: step 6, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the charging core screws: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the six 3.9 mm‑long screws securing the two halves of the charging core.
    Ask FixBot
  7. Fairphone Fairbuds USB-C Port Replacement, Open the charging core: step 7, image 1 of 3 Fairphone Fairbuds USB-C Port Replacement, Open the charging core: step 7, image 2 of 3 Fairphone Fairbuds USB-C Port Replacement, Open the charging core: step 7, image 3 of 3
    • Flip over the charging core and grip its top half, near the pairing button.
    • Lift the top half and swing it over the core, letting it rest on something sturdy.
    • Don't try to separate the two halves, as they're still attached by cables.
    Ask FixBot
  8. Fairphone Fairbuds USB-C Port Replacement, Disconnect the mainboard: step 8, image 1 of 3 Fairphone Fairbuds USB-C Port Replacement, Disconnect the mainboard: step 8, image 2 of 3 Fairphone Fairbuds USB-C Port Replacement, Disconnect the mainboard: step 8, image 3 of 3
    • Use your fingers to pull the left earbud charging cable out of its socket.
    • Don't grip the cable! Only pull on the cable's plastic head.
    • If you're having trouble gripping the cable's head, use the tip of a spudger to push it out of its socket.
    Ask FixBot
  9. Fairphone Fairbuds USB-C Port Replacement: step 9, image 1 of 3 Fairphone Fairbuds USB-C Port Replacement: step 9, image 2 of 3 Fairphone Fairbuds USB-C Port Replacement: step 9, image 3 of 3
    • Since the remaining connectors are next to each other, it can be difficult to grip them with your fingers. The following instructions use a spudger instead.
    • Use the tip of a spudger to push the right earbud cable head out of its socket to disconnect it.
    • Repeat for the USB-C port cable.
    Ask FixBot
  10. Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard screws: step 10, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard screws: step 10, image 2 of 2
    • Use a Phillips screwdriver to remove the two 3.9 mm‑long screws securing the mainboard.
    Ask FixBot
  11. Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard: step 11, image 1 of 3 Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard: step 11, image 2 of 3 Fairphone Fairbuds USB-C Port Replacement, Remove the mainboard: step 11, image 3 of 3
    • Lift the mainboard off its posts in the charging core and remove it.
    Ask FixBot
  12. Fairphone Fairbuds USB-C Port Replacement, Move the cable: step 12, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Move the cable: step 12, image 2 of 2
    • Move the USB-C port cable out of its groove next to the screw peg.
    Ask FixBot
  13. Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port screws: step 13, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port screws: step 13, image 2 of 2
    • Use a Phillips screwdriver to remove the two 3.9 mm‑long screws securing the USB-C port.
    Ask FixBot
  14. Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port: step 14, image 1 of 2 Fairphone Fairbuds USB-C Port Replacement, Remove the USB-C port: step 14, image 2 of 2
    • Lift the USB-C port out of the charging core and remove it.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
244,748 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,226 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 58
All Time: 1,269
