Introduction
Go to step 1 ↓Use this guide to replace the mainboard in your Fairphone Fairbuds.
You should replace your mainboard if your charging case isn't working, and you've ruled out any issues with the charging case's battery.
Tools
Spudger4.9
Flip your charging case upside down.
Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
Use a Phillips screwdriver to remove the six 3.9 mm‑long screws securing the two halves of the charging core.
Flip over the charging core and grip its top half, near the pairing button.
Lift the top half and swing it over the core, letting it rest on something sturdy.
Use your fingers to pull the left earbud charging cable out of its socket.
Use a Phillips screwdriver to remove the two 3.9 mm‑long screws securing the mainboard.
Lift the mainboard off its posts in the charging core and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2 other people completed this guide.
