Fairphone Fairbuds Earbud Battery Replacement
  1. Fairphone Fairbuds Earbud Battery Replacement, Remove the earbuds: step 1, image 1 of 2 Fairphone Fairbuds Earbud Battery Replacement, Remove the earbuds: step 1, image 2 of 2
    • Remove your earbuds from the charging case.
    Ask FixBot
  2. Fairphone Fairbuds Earbud Battery Replacement, Remove the silicone ring: step 2, image 1 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the silicone ring: step 2, image 2 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the silicone ring: step 2, image 3 of 3
    • Use your fingers or tweezers to pull the silicone ring off its groove in the earbud.
    • If you're reusing the silicone ring, don't stretch it too far or it won't fit snug in its groove.
    • Remove the silicone ring.
    • During reassembly, align the tab on the silicone ring with the notch on the earbud to ensure the ring fits snug.
    Ask FixBot
  3. Fairphone Fairbuds Earbud Battery Replacement, Remove the battery: step 3, image 1 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the battery: step 3, image 2 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the battery: step 3, image 3 of 3
    • Insert the pointed end of a spudger into the notch on the battery tray, above the plus and minus sign.
    • Pry up to unlatch the battery tray from the earbud.
    Ask FixBot
  4. Fairphone Fairbuds Earbud Battery Replacement: step 4, image 1 of 3 Fairphone Fairbuds Earbud Battery Replacement: step 4, image 2 of 3 Fairphone Fairbuds Earbud Battery Replacement: step 4, image 3 of 3
    • Swing open the battery tray and remove the battery.
    Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
244,823 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
1 Guide Comment
Are these going to be available in the USA? If so are the battery replacements going to be available in the USA?
I wish a company would make some non-ANC airpod type headphones that use standard hearing aid batteries i can buy at the grocery store.
Zak Whipp - Reply Share
Past 24 Hours: 22
Past 7 Days: 155
Past 30 Days: 457
All Time: 7,510
