Fairphone Fairbuds Charging Core Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
8
Past 7 Days:
37
Past 30 Days:
124
All Time:
1,604
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the charging core for your Fairphone Fairbuds.
The charging core includes the USB-C port, the mainboard, and the contacts for the earbuds and the charging core battery to charge. It doesn't include the charging core battery.
You should replace your charging core if your earbuds aren't charging properly, and you've ruled out any issues with the earbuds themselves or with the charging core battery.
You can buy a replacement charging core from Fairphone here.
Parts
Tools
    1. Fairphone Fairbuds Charging Core Replacement, Remove the earbuds: step 1, image 1 of 2 Fairphone Fairbuds Charging Core Replacement, Remove the earbuds: step 1, image 2 of 2
      • Remove your earbuds from the charging case.
      Ask FixBot
    1. Fairphone Fairbuds Charging Core Replacement, Remove the outer shell screw: step 2, image 1 of 2 Fairphone Fairbuds Charging Core Replacement, Remove the outer shell screw: step 2, image 2 of 2
      • Flip your charging case upside down.
      • Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
      Ask FixBot
    2. Fairphone Fairbuds Charging Core Replacement, Remove the battery: step 3, image 1 of 2 Fairphone Fairbuds Charging Core Replacement, Remove the battery: step 3, image 2 of 2
      • Flip up the bottom of the outer shell to expose the battery.
      Ask FixBot
    3. Fairphone Fairbuds Charging Core Replacement: step 4, image 1 of 3 Fairphone Fairbuds Charging Core Replacement: step 4, image 2 of 3 Fairphone Fairbuds Charging Core Replacement: step 4, image 3 of 3
      • Use your finger to pry up the battery at its notch and remove it.
      Ask FixBot
    1. Fairphone Fairbuds Charging Core Replacement, Remove the charging core: step 5, image 1 of 2 Fairphone Fairbuds Charging Core Replacement, Remove the charging core: step 5, image 2 of 2
      • Lift the charging core out of the outer shell and remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
251,331 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,178 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 37
Past 30 Days: 124
All Time: 1,604
