Fairphone Fairbuds Charging Case Battery Replacement
  1. Fairphone Fairbuds Charging Case Battery Replacement, Remove the outer shell screw: step 1, image 1 of 2 Fairphone Fairbuds Charging Case Battery Replacement, Remove the outer shell screw: step 1, image 2 of 2
    • Flip your charging case upside down.
    • Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
    Ask FixBot
  2. Fairphone Fairbuds Charging Case Battery Replacement, Remove the battery: step 2, image 1 of 2 Fairphone Fairbuds Charging Case Battery Replacement, Remove the battery: step 2, image 2 of 2
    • Flip up the bottom of the outer shell to expose the battery.
    Ask FixBot
  3. Fairphone Fairbuds Charging Case Battery Replacement: step 3, image 1 of 3 Fairphone Fairbuds Charging Case Battery Replacement: step 3, image 2 of 3 Fairphone Fairbuds Charging Case Battery Replacement: step 3, image 3 of 3
    • Use your finger to pry up the battery at its notch and remove it.
    Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
244,856 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 127
All Time: 2,118
