Up to 20% off select tools
Fairphone 5 Screen Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
13
Past 7 Days:
73
Past 30 Days:
291
All Time:
9,493
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace a shattered or broken screen in your Fairphone 5.
    1. Fairphone 5 Screen Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
      • Unplug all cables and power down your phone.
      • Press the power and volume up buttons at the same time to bring up the shutdown menu.
      Ask FixBot
    1. Fairphone 5 Screen Replacement, Pry up the back cover: step 2, image 1 of 2 Fairphone 5 Screen Replacement, Pry up the back cover: step 2, image 2 of 2
      • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
      • Pry up the back cover to release the bottom right corner clips.
      Ask FixBot
    2. Fairphone 5 Screen Replacement, Remove the back cover: step 3, image 1 of 3 Fairphone 5 Screen Replacement, Remove the back cover: step 3, image 2 of 3 Fairphone 5 Screen Replacement, Remove the back cover: step 3, image 3 of 3
      • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
      • Lift the back cover away from the phone to release the clips around its perimeter.
      • Remove the back cover.
      • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
      Ask FixBot
    1. Fairphone 5 Screen Replacement, Remove the battery: step 4, image 1 of 3 Fairphone 5 Screen Replacement, Remove the battery: step 4, image 2 of 3 Fairphone 5 Screen Replacement, Remove the battery: step 4, image 3 of 3
      • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
      • Remove the battery.
      • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
      Ask FixBot
    1. Fairphone 5 Screen Replacement, Unfasten the screen: step 5, image 1 of 2 Fairphone 5 Screen Replacement, Unfasten the screen: step 5, image 2 of 2
      • Use a Phillips driver to remove the eight 3.9 mm‑long screws securing the screen.
      Ask FixBot
    2. Fairphone 5 Screen Replacement, Reposition the screen: step 6, image 1 of 3 Fairphone 5 Screen Replacement, Reposition the screen: step 6, image 2 of 3 Fairphone 5 Screen Replacement, Reposition the screen: step 6, image 3 of 3
      • While supporting the screen, lift the phone with the screen facing downward.
      • Pull the phone frame upward to separate it from the screen.
      • Flip the screen and frame over and lay them down with the screen resting over the top left portion of the frame, exposing the display cable.
      • Don't strain the cable. You only need enough space to access the screen press connector.
      Ask FixBot
    3. Fairphone 5 Screen Replacement, Remove the screen: step 7, image 1 of 3 Fairphone 5 Screen Replacement, Remove the screen: step 7, image 2 of 3 Fairphone 5 Screen Replacement, Remove the screen: step 7, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the screen press connector.
      • Remove the screen.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
3 other people completed this guide.
Author
with
Alex Diaz-Kokaisl
253,211 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 73
Past 30 Days: 291
All Time: 9,493
