Fairphone 5 Loudspeaker Replacement
    1. Fairphone 5 Loudspeaker Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
      • Unplug all cables and power down your phone.
      • Press the power and volume up buttons at the same time to bring up the shutdown menu.
      Ask FixBot
    1. Fairphone 5 Loudspeaker Replacement, Pry up the back cover: step 2, image 1 of 2 Fairphone 5 Loudspeaker Replacement, Pry up the back cover: step 2, image 2 of 2
      • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
      • Pry up the back cover to release the bottom right corner clips.
      Ask FixBot
    2. Fairphone 5 Loudspeaker Replacement, Remove the back cover: step 3, image 1 of 3 Fairphone 5 Loudspeaker Replacement, Remove the back cover: step 3, image 2 of 3 Fairphone 5 Loudspeaker Replacement, Remove the back cover: step 3, image 3 of 3
      • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
      • Lift the back cover away from the phone to release the clips around its perimeter.
      • Remove the back cover.
      • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
      Ask FixBot
    1. Fairphone 5 Loudspeaker Replacement, Remove the battery: step 4, image 1 of 3 Fairphone 5 Loudspeaker Replacement, Remove the battery: step 4, image 2 of 3 Fairphone 5 Loudspeaker Replacement, Remove the battery: step 4, image 3 of 3
      • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
      • Remove the battery.
      • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
      Ask FixBot
    1. Fairphone 5 Loudspeaker Replacement, Unfasten the loudspeaker: step 5, image 1 of 2 Fairphone 5 Loudspeaker Replacement, Unfasten the loudspeaker: step 5, image 2 of 2
      • Use a Phillips driver to remove the five 4.9 mm‑long screws securing the loudspeaker.
      Ask FixBot
    2. Fairphone 5 Loudspeaker Replacement, Remove the loudspeaker: step 6, image 1 of 3 Fairphone 5 Loudspeaker Replacement, Remove the loudspeaker: step 6, image 2 of 3 Fairphone 5 Loudspeaker Replacement, Remove the loudspeaker: step 6, image 3 of 3
      • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right corner of the loudspeaker.
      • Pry up the loudspeaker and pull it away from the bottom edge of the phone to separate it from the frame.
      • During reassembly, insert the bottom edge of the loudspeaker into its slot in the frame before pressing the loudspeaker into place.
      Ask FixBot
Alex Diaz-Kokaisl
250,409 Reputation
1,203 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 92
All Time: 1,692
