Up to 20% off select tools
Fairphone 5 Front Camera Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
102
All Time:
1,425
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace a damaged front camera in your Fairphone 5.
    1. Fairphone 5 Front Camera Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
      • Unplug all cables and power down your phone.
      • Press the power and volume up buttons at the same time to bring up the shutdown menu.
      Ask FixBot
    1. Fairphone 5 Front Camera Replacement, Pry up the back cover: step 2, image 1 of 2 Fairphone 5 Front Camera Replacement, Pry up the back cover: step 2, image 2 of 2
      • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
      • Pry up the back cover to release the bottom right corner clips.
      Ask FixBot
    2. Fairphone 5 Front Camera Replacement, Remove the back cover: step 3, image 1 of 3 Fairphone 5 Front Camera Replacement, Remove the back cover: step 3, image 2 of 3 Fairphone 5 Front Camera Replacement, Remove the back cover: step 3, image 3 of 3
      • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
      • Lift the back cover away from the phone to release the clips around its perimeter.
      • Remove the back cover.
      • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
      Ask FixBot
    1. Fairphone 5 Front Camera Replacement, Remove the battery: step 4, image 1 of 3 Fairphone 5 Front Camera Replacement, Remove the battery: step 4, image 2 of 3 Fairphone 5 Front Camera Replacement, Remove the battery: step 4, image 3 of 3
      • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
      • Remove the battery.
      • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
      Ask FixBot
    1. Fairphone 5 Front Camera Replacement, Unfasten the connector cover: step 5, image 1 of 2 Fairphone 5 Front Camera Replacement, Unfasten the connector cover: step 5, image 2 of 2
      • Use a Phillips driver to remove the 3.9 mm-long screw securing the top unit connector cover at the bottom left corner.
      • The connector cover is labeled with a "1" and a triangle pointing downward.
      Ask FixBot
    2. Fairphone 5 Front Camera Replacement, Pry up the connector cover: step 6, image 1 of 3 Fairphone 5 Front Camera Replacement, Pry up the connector cover: step 6, image 2 of 3 Fairphone 5 Front Camera Replacement, Pry up the connector cover: step 6, image 3 of 3
      • Insert your fingernail, or a pry tool like a spudger, under the notch at the left edge of the connector cover.
      • Pry up the cover to separate it from the top unit.
      • The cover is connected to the top unit by a plastic cord. Don't try to completely remove it from the top unit.
      Ask FixBot
    3. Fairphone 5 Front Camera Replacement, Disconnect the top unit: step 7, image 1 of 2 Fairphone 5 Front Camera Replacement, Disconnect the top unit: step 7, image 2 of 2
      • While holding the cover out of the way, use a spudger to pry up and disconnect the top unit press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    4. Fairphone 5 Front Camera Replacement, Unfasten the top unit: step 8, image 1 of 2 Fairphone 5 Front Camera Replacement, Unfasten the top unit: step 8, image 2 of 2
      • Use a Phillips driver to remove the six 4.9 mm‑long screws securing the top unit.
      Ask FixBot
    5. Fairphone 5 Front Camera Replacement, Remove the top unit: step 9, image 1 of 3 Fairphone 5 Front Camera Replacement, Remove the top unit: step 9, image 2 of 3 Fairphone 5 Front Camera Replacement, Remove the top unit: step 9, image 3 of 3
      • Insert the flat end of a spudger under the screw hole along the bottom edge of the top unit.
      • Pry up to release the clips securing the top unit to the phone frame.
      • During reassembly, insert the top edge of the top unit at a downward angle into the frame before pressing it down and re-engaging the clips.
      Ask FixBot
    1. Fairphone 5 Front Camera Replacement, Remove the front camera: step 10, image 1 of 3 Fairphone 5 Front Camera Replacement, Remove the front camera: step 10, image 2 of 3 Fairphone 5 Front Camera Replacement, Remove the front camera: step 10, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the front camera press connector.
      • Lift the front camera out of its slot in the frame and remove it.
      Ask FixBot
Author
with
Alex Diaz-Kokaisl
253,249 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 102
All Time: 1,425
