Fairphone 4 Loudspeaker Replacement
    1. Fairphone 4 Loudspeaker Replacement, Pry the back cover up: step 1, image 1 of 2 Fairphone 4 Loudspeaker Replacement, Pry the back cover up: step 1, image 2 of 2
      • Be sure to power off your phone before you begin.
      • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
      • Pry the back cover up to start separating its plastic clips.
      Ask FixBot
    2. Fairphone 4 Loudspeaker Replacement: step 2, image 1 of 3 Fairphone 4 Loudspeaker Replacement: step 2, image 2 of 3 Fairphone 4 Loudspeaker Replacement: step 2, image 3 of 3
      • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
      Ask FixBot
    3. Fairphone 4 Loudspeaker Replacement: step 3, image 1 of 3 Fairphone 4 Loudspeaker Replacement: step 3, image 2 of 3 Fairphone 4 Loudspeaker Replacement: step 3, image 3 of 3
      • Slide along the bottom of the phone to loosen the plastic clips.
      Ask FixBot
    4. Fairphone 4 Loudspeaker Replacement: step 4, image 1 of 3 Fairphone 4 Loudspeaker Replacement: step 4, image 2 of 3 Fairphone 4 Loudspeaker Replacement: step 4, image 3 of 3
      • Slide along the left side of the phone to loosen the plastic clips.
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
      Ask FixBot
    1. Fairphone 4 Loudspeaker Replacement, Lever up the Battery: step 5, image 1 of 3 Fairphone 4 Loudspeaker Replacement, Lever up the Battery: step 5, image 2 of 3 Fairphone 4 Loudspeaker Replacement, Lever up the Battery: step 5, image 3 of 3
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      • Lift the battery out of its recess and remove it.
      • Remove the battery.
      Ask FixBot
    1. Fairphone 4 Loudspeaker Replacement, Unscrew the loudspeaker: step 6, image 1 of 1
      • Remove the six 4.8 mm-long Phillips screws.
      Ask FixBot
    2. Fairphone 4 Loudspeaker Replacement, Slide beneath the loudspeaker: step 7, image 1 of 2 Fairphone 4 Loudspeaker Replacement, Slide beneath the loudspeaker: step 7, image 2 of 2
      • Use an opening pick to slide beneath the loudspeaker.
      • Slide the opening pick to the right side of the loudspeaker to release the clips that hold it in place.
      Ask FixBot
    3. Fairphone 4 Loudspeaker Replacement, Lift up the loudspeaker: step 8, image 1 of 2 Fairphone 4 Loudspeaker Replacement, Lift up the loudspeaker: step 8, image 2 of 2
      • Slide the opening pick to the left side of the loudspeaker to release the clips that hold it in place.
      • Twist the opening pick to lift up the loudspeaker.
      Ask FixBot
    4. Fairphone 4 Loudspeaker Replacement, Remove the loudspeaker: step 9, image 1 of 2 Fairphone 4 Loudspeaker Replacement, Remove the loudspeaker: step 9, image 2 of 2
      • Grab the loudspeaker and flip it towards the bottom to remove it.
      Ask FixBot
Manuel Haeussermann
27,023 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 115
All Time: 3,376
