Up to 20% off select tools
Fairphone 4 Front Camera Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
101
All Time:
3,077
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front camera in your Fairphone 4.
    1. Fairphone 4 Front Camera Replacement, Pry the back cover up: step 1, image 1 of 2 Fairphone 4 Front Camera Replacement, Pry the back cover up: step 1, image 2 of 2
      • Be sure to power off your phone before you begin.
      • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
      • Pry the back cover up to start separating its plastic clips.
      Ask FixBot
    2. Fairphone 4 Front Camera Replacement: step 2, image 1 of 3 Fairphone 4 Front Camera Replacement: step 2, image 2 of 3 Fairphone 4 Front Camera Replacement: step 2, image 3 of 3
      • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
      Ask FixBot
    3. Fairphone 4 Front Camera Replacement: step 3, image 1 of 3 Fairphone 4 Front Camera Replacement: step 3, image 2 of 3 Fairphone 4 Front Camera Replacement: step 3, image 3 of 3
      • Slide along the bottom of the phone to loosen the plastic clips.
      Ask FixBot
    4. Fairphone 4 Front Camera Replacement: step 4, image 1 of 3 Fairphone 4 Front Camera Replacement: step 4, image 2 of 3 Fairphone 4 Front Camera Replacement: step 4, image 3 of 3
      • Slide along the left side of the phone to loosen the plastic clips.
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
      Ask FixBot
    1. Fairphone 4 Front Camera Replacement, Lever up the Battery: step 5, image 1 of 3 Fairphone 4 Front Camera Replacement, Lever up the Battery: step 5, image 2 of 3 Fairphone 4 Front Camera Replacement, Lever up the Battery: step 5, image 3 of 3
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      • Lift the battery out of its recess and remove it.
      • Remove the battery.
      Ask FixBot
    1. Fairphone 4 Front Camera Replacement, Unscrew the cable cover: step 6, image 1 of 1
      • Remove the 4.8 mm-long Phillips screw.
      Ask FixBot
    2. Fairphone 4 Front Camera Replacement, Remove the cable cover: step 7, image 1 of 2 Fairphone 4 Front Camera Replacement, Remove the cable cover: step 7, image 2 of 2
      • Insert an opening pick beneath the cover near the triangular mark.
      • Twist the opening pick to pry the cover up.
      • Remove the cover.
      Ask FixBot
    3. Fairphone 4 Front Camera Replacement, Disconnect cables: step 8, image 1 of 3 Fairphone 4 Front Camera Replacement, Disconnect cables: step 8, image 2 of 3 Fairphone 4 Front Camera Replacement, Disconnect cables: step 8, image 3 of 3
      • Use a spudger or an opening pick to pry up and disconnect the two camera connection cables.
      Ask FixBot
    4. Fairphone 4 Front Camera Replacement: step 9, image 1 of 3 Fairphone 4 Front Camera Replacement: step 9, image 2 of 3 Fairphone 4 Front Camera Replacement: step 9, image 3 of 3
      • Lift up the right connector to reveal the additional connector beneath it.
      • Use a spudger or an opening pick to pry up and disconnect the third camera connection cable.
      Ask FixBot
    5. Fairphone 4 Front Camera Replacement, Unscrew the rear camera module: step 10, image 1 of 1
      • Remove the five 4.8 mm-long Phillips screws.
      Ask FixBot
    6. Fairphone 4 Front Camera Replacement: step 11, image 1 of 3 Fairphone 4 Front Camera Replacement: step 11, image 2 of 3 Fairphone 4 Front Camera Replacement: step 11, image 3 of 3
      • Use an opening pick to slide underneath the rear camera module.
      • Slide the opening pick along the rear camera module to release the clips that hold it in place.
      Ask FixBot
    7. Fairphone 4 Front Camera Replacement: step 12, image 1 of 1
      • Lift the rear camera module and remove it.
      Ask FixBot
    1. Fairphone 4 Front Camera Replacement, Disconnect the front camera cable: step 13, image 1 of 2 Fairphone 4 Front Camera Replacement, Disconnect the front camera cable: step 13, image 2 of 2
      • Use an opening pick to pry up and disconnect the front camera cable.
      Ask FixBot
    2. Fairphone 4 Front Camera Replacement, Lift out the front camera: step 14, image 1 of 2 Fairphone 4 Front Camera Replacement, Lift out the front camera: step 14, image 2 of 2
      • Use an opening pick to lift out the front camera by carefully pulling it away from the frame so it pops out of its recess.
      • Alternatively you can turn the phone over to let gravity to do its part.
      Ask FixBot
    3. Fairphone 4 Front Camera Replacement, Remove the front camera: step 15, image 1 of 1
      • Grab the front camera and remove it.
      Ask FixBot
Author
with
Manuel Haeussermann
27,784 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 101
All Time: 3,077
