Fairphone 4 Battery Replacement
    1. Fairphone 4 Battery Replacement, Pry the back cover up: step 1, image 1 of 2 Fairphone 4 Battery Replacement, Pry the back cover up: step 1, image 2 of 2
      • Be sure to power off your phone before you begin.
      • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
      • Pry the back cover up to start separating its plastic clips.
      Ask FixBot
    2. Fairphone 4 Battery Replacement: step 2, image 1 of 3 Fairphone 4 Battery Replacement: step 2, image 2 of 3 Fairphone 4 Battery Replacement: step 2, image 3 of 3
      • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
      Ask FixBot
    3. Fairphone 4 Battery Replacement: step 3, image 1 of 3 Fairphone 4 Battery Replacement: step 3, image 2 of 3 Fairphone 4 Battery Replacement: step 3, image 3 of 3
      • Slide along the bottom of the phone to loosen the plastic clips.
      Ask FixBot
    4. Fairphone 4 Battery Replacement: step 4, image 1 of 3 Fairphone 4 Battery Replacement: step 4, image 2 of 3 Fairphone 4 Battery Replacement: step 4, image 3 of 3
      • Slide along the left side of the phone to loosen the plastic clips.
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
      Ask FixBot
    1. Fairphone 4 Battery Replacement, Lever up the Battery: step 5, image 1 of 3 Fairphone 4 Battery Replacement, Lever up the Battery: step 5, image 2 of 3 Fairphone 4 Battery Replacement, Lever up the Battery: step 5, image 3 of 3
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      • Lift the battery out of its recess and remove it.
      • Remove the battery.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
14 other people completed this guide.
Manuel Haeussermann
27,023 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
2 Guide Comments
I am not sure steps 2,3,4 are really necessary in this guide.
Bartłomiej Tokarzewski - Reply Share
Can I find a compatible battery if I live in a country full of normies who use stock android and iphones?
Amit Yaron - Reply Share
Past 24 Hours: 19
Past 7 Days: 99
Past 30 Days: 321
All Time: 14,581
