Up to 20% off select tools
Fairphone 3 Top Module Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
120
All Time:
6,584
Comments: 28
25 comments on steps, 3 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the top module in your Fairphone 3.
    1. Fairphone 3 Top Module Replacement, Back Cover: step 1, image 1 of 2 Fairphone 3 Top Module Replacement, Back Cover: step 1, image 2 of 2
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
      • Pry the back cover up to start separating its plastic clips.
      Ask FixBot
    2. Fairphone 3 Top Module Replacement: step 2, image 1 of 3 Fairphone 3 Top Module Replacement: step 2, image 2 of 3 Fairphone 3 Top Module Replacement: step 2, image 3 of 3
      • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
      Ask FixBot
    1. Fairphone 3 Top Module Replacement, Battery: step 3, image 1 of 2 Fairphone 3 Top Module Replacement, Battery: step 3, image 2 of 2
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      • Lever the battery up until you can get a good grip.
      Ask FixBot
    2. Fairphone 3 Top Module Replacement: step 4, image 1 of 2 Fairphone 3 Top Module Replacement: step 4, image 2 of 2
      • Lift the battery out of its recess and remove it.
      Ask FixBot
    1. Fairphone 3 Top Module Replacement, Display Assembly: step 5, image 1 of 1
      • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
      • Remove the thirteen Phillips #00 screws (4 mm length).
      Ask FixBot
    2. Fairphone 3 Top Module Replacement: step 6, image 1 of 3 Fairphone 3 Top Module Replacement: step 6, image 2 of 3 Fairphone 3 Top Module Replacement: step 6, image 3 of 3
      • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
      • Insert an opening pick between the midframe and the display module on the right edge of the phone.
      • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
      Ask FixBot
    3. Fairphone 3 Top Module Replacement: step 7, image 1 of 2 Fairphone 3 Top Module Replacement: step 7, image 2 of 2
      • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
      Ask FixBot
    4. Fairphone 3 Top Module Replacement: step 8, image 1 of 2 Fairphone 3 Top Module Replacement: step 8, image 2 of 2
      • Slide the opening pick along the left side to pry the display module up.
      • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
      Ask FixBot
    5. Fairphone 3 Top Module Replacement: step 9, image 1 of 2 Fairphone 3 Top Module Replacement: step 9, image 2 of 2
      • Remove the display assembly.
      • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
      • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
      Ask FixBot
    1. Fairphone 3 Top Module Replacement, Top Module: step 10, image 1 of 1
      • Remove the two 4.1mm-long Phillips #00 screws.
      Ask FixBot
    2. Fairphone 3 Top Module Replacement: step 11, image 1 of 2 Fairphone 3 Top Module Replacement: step 11, image 2 of 2
      • Use a spudger to pry up and disconnect the top module connecting cable.
      Ask FixBot
    3. Fairphone 3 Top Module Replacement: step 12, image 1 of 2 Fairphone 3 Top Module Replacement: step 12, image 2 of 2
      • Use a spudger to pry up the top module of your Fairphone 3.
      Ask FixBot
    4. Fairphone 3 Top Module Replacement: step 13, image 1 of 2 Fairphone 3 Top Module Replacement: step 13, image 2 of 2
      • Use your fingers to remove the top module.
      Ask FixBot
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
12 other people completed this guide.
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
3 Guide Comments
I just did exactly that, and the camera won't work. both of the cameras. when I open the camera app, it is all black, and seems like still loading for around 10 seconds, and afterwards it prompts the error: "open camera error id =0".
I tried to replace it back to the old top module and the problem remained the same.. @fairops
tried the fairphone builtin checks from "myFairphone" app, and both front and back camera failed for not presenting anything.. used the automatic form to reach fairphone customer support, but they should reply me in about 9 days...
meanwhile I cannot use my phone camera!
so please if anyone knows how to handle it please help
Danks - Reply Share
now I see I can't use my flashlight too, the button is disabled and it says "camera in use"... although the green sign that should be on the top right corner to inform of camera status does not appear, so it seems like the phone thinks the camera is in use although it is not in use... disturbing..
Danks - Reply Share
solved! (kinda..)
the connecting part of the new top module I tried to install was dirty, and so, after installing it, the connecting part in the phone itself got dirty too, which blocked the old top module to connect back successfully.
after cleaning the old top module and the connecting part of the phone, the old top module connected back successfully!
although when I tried to clean the dirty new one(which caused the troubles from the first place), and connected it, it still didn't work.
so not greatly happy about it I keep using the old top module.
disclaimer: the new top module I tried to install was a top module from a fairphone that was ran over by a car, lucky me that other parts survived and I'm currently using them on my fairphone without any troubles.
Danks - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 120
All Time: 6,584
