Up to 20% off select tools
Fairphone 3 Battery Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
38
Past 30 Days:
169
All Time:
13,286
Comments: 5
5 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 seconds
Difficulty: Very easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to remove or to replace a worn-out or dead battery in your Fairphone 3.
If your battery is swollen, take appropriate precautions.
    1. Fairphone 3 Battery Replacement, Back Cover: step 1, image 1 of 2 Fairphone 3 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
      • Pry the back cover up to start separating its plastic clips.
      Ask FixBot
    2. Fairphone 3 Battery Replacement: step 2, image 1 of 3 Fairphone 3 Battery Replacement: step 2, image 2 of 3 Fairphone 3 Battery Replacement: step 2, image 3 of 3
      • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
      Ask FixBot
    1. Fairphone 3 Battery Replacement, Battery: step 3, image 1 of 2 Fairphone 3 Battery Replacement, Battery: step 3, image 2 of 2
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      • Lever the battery up until you can get a good grip.
      Ask FixBot
    2. Fairphone 3 Battery Replacement: step 4, image 1 of 2 Fairphone 3 Battery Replacement: step 4, image 2 of 2
      • Lift the battery out of its recess and remove it.
      Ask FixBot
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
17 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
5 Guide Comments
Vielen Dank!
Einfach und direkt umgesetzt..
carola kamp - Reply Share
Imagine if all cellphone producers made it this easy :-)
Martin Andre Bae Pedersen - Reply Share
Anything to keep in mind, e.g. should I first give the phone a full charge once the new battery is installed?
Luke D - Reply Share
Where can I get the battery in Nigeria, if not how can I get one coz the one on my phone is weak
Mueez - Reply Share
Hi, I have a Fairphone 3 which I bought on Ebay maybe 4 years ago. Recently I've noticed the battery refuse to charge. I tried plugging it in with different adaptors and leads, also with a portable charger and that seemed to work for a while. But now it is becoming more difficult and I worry that I'll get caught out in a critical moment like not having a ticket read in crucial QR situation. Do you think this is a dying battery? Or should I take it to a shop specialising in FPs?
veryan_weston - Reply Share
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 169
All Time: 13,286
