Up to 20% off select tools
Fairphone 2 Display Assembly Replacement
Views: 19K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
135
All Time:
19,239
Comments: 35
28 comments on steps, 7 guide comments.
Go to guide comments
Completed: 38
38 people have marked this guide "completed." Will you be next?
Favorites: 23
23 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replace the Display Assembly of your Fairphone 2.
    1. Fairphone 2 Display Assembly Replacement, Slim Case: step 1, image 1 of 3 Fairphone 2 Display Assembly Replacement, Slim Case: step 1, image 2 of 3 Fairphone 2 Display Assembly Replacement, Slim Case: step 1, image 3 of 3
      • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
      • Pull up the back part of the slim case to separate the small snap fit connections.
      • Remove the back part of the slim case.
      Ask FixBot
    2. Fairphone 2 Display Assembly Replacement: step 2, image 1 of 3 Fairphone 2 Display Assembly Replacement: step 2, image 2 of 3 Fairphone 2 Display Assembly Replacement: step 2, image 3 of 3
      • Get in between the front part of the slim case and the phone's body with your thumb nail.
      • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
      Ask FixBot
    3. Fairphone 2 Display Assembly Replacement: step 3, image 1 of 1
      • Remove the front part of the slim case.
      Ask FixBot
    1. Fairphone 2 Display Assembly Replacement, Battery: step 4, image 1 of 3 Fairphone 2 Display Assembly Replacement, Battery: step 4, image 2 of 3 Fairphone 2 Display Assembly Replacement, Battery: step 4, image 3 of 3
      • Push the battery toward the top of the phone.
      • Pull the battery out away from the phone.
      Ask FixBot
    1. Fairphone 2 Display Assembly Replacement, Display Assembly: step 5, image 1 of 3 Fairphone 2 Display Assembly Replacement, Display Assembly: step 5, image 2 of 3 Fairphone 2 Display Assembly Replacement, Display Assembly: step 5, image 3 of 3
      • After taking out the battery you can unlock the display assembly.
      • Flip the two blue switches to the inner position.
      • Slide the display assembly towards the bottom of the phone.
      Ask FixBot
      • Another possible way of sliding the display assembly open.
      Ask FixBot
    2. Fairphone 2 Display Assembly Replacement: step 7, image 1 of 1
      • Take off the display assembly.
      Ask FixBot
38 other people completed this guide.
Author
with
Tobias Isakeit
136,836 Reputation
189 Guides authored
7 Guide Comments
Bonjour ! Es-tu bien sûr d'avoir déplacé les deux languettes bleues vers l'intérieur pour libérer l'écran ? Si oui, n'hésite pas à appliquer une certaine force sur l'écran (appuyer et déplacer vers toi).
Oriane Petit - Reply Share
Keine chance das Display zu bewegen. Nach 1h versuchen und allen FP2 Tutorials Videos bin ich immer noch gleichweit. Definitiv Verbesserung würdig. Für weitere Tipps bin ich dankbar, wird es sonst wieder zurück senden :-(
Christian Rapp - Reply Share
Ich habe keine blauen Schalter, ich rede vom FP 1U, ist das korrekt?
Birgit - Reply Share
FP 1U: Ich habe keine blauen Schalter.....
The Display seem to be stuck completely, any tips on how to move it?
siohdk - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 135
All Time: 19,239
