Up to 20% off select tools
Fairphone 2 Battery Replacement
Views: 134K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
131
All Time:
134,450
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 19
19 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 seconds
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the battery in your Fairphone 2 is easy and requires no tools.
    1. Fairphone 2 Battery Replacement, Slim Case: step 1, image 1 of 3 Fairphone 2 Battery Replacement, Slim Case: step 1, image 2 of 3 Fairphone 2 Battery Replacement, Slim Case: step 1, image 3 of 3
      • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
      • Pull up the back part of the slim case to separate the small snap fit connections.
      • Remove the back part of the slim case.
      Ask FixBot
    2. Fairphone 2 Battery Replacement: step 2, image 1 of 3 Fairphone 2 Battery Replacement: step 2, image 2 of 3 Fairphone 2 Battery Replacement: step 2, image 3 of 3
      • Get in between the front part of the slim case and the phone's body with your thumb nail.
      • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
      Ask FixBot
    3. Fairphone 2 Battery Replacement: step 3, image 1 of 1
      • Remove the front part of the slim case.
      Ask FixBot
    1. Fairphone 2 Battery Replacement, Battery: step 4, image 1 of 3 Fairphone 2 Battery Replacement, Battery: step 4, image 2 of 3 Fairphone 2 Battery Replacement, Battery: step 4, image 3 of 3
      • Push the battery toward the top of the phone.
      • Pull the battery out away from the phone.
      Ask FixBot
10 other people completed this guide.
Author
with
Tobias Isakeit
136,836 Reputation
189 Guides authored
1 Guide Comment
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
Jim Kinnibrugh - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 131
All Time: 134,450
