Fairphone 1 Motherboard Replacement
    1. Fairphone 1 Motherboard Replacement, Back Cover: step 1, image 1 of 3 Fairphone 1 Motherboard Replacement, Back Cover: step 1, image 2 of 3 Fairphone 1 Motherboard Replacement, Back Cover: step 1, image 3 of 3
      • There is a small indentation in the side of the phone near the bottom of the back cover.
      • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
      Ask FixBot
    2. Fairphone 1 Motherboard Replacement: step 2, image 1 of 3 Fairphone 1 Motherboard Replacement: step 2, image 2 of 3 Fairphone 1 Motherboard Replacement: step 2, image 3 of 3
      • Slide the back cover down and remove it from the phone.
      Ask FixBot
    1. Fairphone 1 Motherboard Replacement, Battery: step 3, image 1 of 3 Fairphone 1 Motherboard Replacement, Battery: step 3, image 2 of 3 Fairphone 1 Motherboard Replacement, Battery: step 3, image 3 of 3
      • There is a small indentation in the back of the phone just below the battery.
      • Use a fingernail in this indentation to push the battery toward the top of the phone
      • Pull the battery out away from the phone.
      Ask FixBot
    2. Fairphone 1 Motherboard Replacement: step 4, image 1 of 1
      • Remove the battery from your Fairphone.
      Ask FixBot
    1. Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: step 5, image 1 of 3 Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: step 5, image 2 of 3 Fairphone 1 Motherboard Replacement, SIM and MicroSD Card: step 5, image 3 of 3
      • Use your finger to slide the SIM card straight down out of its tray.
      • Remove the SIM card from your Fairphone.
      • Repeat this procedure if you have a second SIM card.
      • Be sure to remove all SIM cards before servicing your phone.
      Ask FixBot
    2. Fairphone 1 Motherboard Replacement: step 6, image 1 of 2 Fairphone 1 Motherboard Replacement: step 6, image 2 of 2
      • If you have a microSD card, use your finger to slide it straight out of its slot.
      • Remove the microSD card from your phone.
      Ask FixBot
    1. Fairphone 1 Motherboard Replacement, Midframe Assembly: step 7, image 1 of 1
      • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Fairphone 1 Motherboard Replacement: step 8, image 1 of 3 Fairphone 1 Motherboard Replacement: step 8, image 2 of 3 Fairphone 1 Motherboard Replacement: step 8, image 3 of 3
      • The midframe is secured to the display assembly by several small plastic clips.
      • Use an opening pick to carefully pry the midframe away from the display assembly.
      • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
      Ask FixBot
    3. Fairphone 1 Motherboard Replacement: step 9, image 1 of 2 Fairphone 1 Motherboard Replacement: step 9, image 2 of 2
      • Carefully round the corner, separating the midframe from the display assembly.
      Ask FixBot
    4. Fairphone 1 Motherboard Replacement: step 10, image 1 of 1
      • After rounding the next corner, the midframe should be free along the bottom and the sides.
      Ask FixBot
    5. Fairphone 1 Motherboard Replacement: step 11, image 1 of 3 Fairphone 1 Motherboard Replacement: step 11, image 2 of 3 Fairphone 1 Motherboard Replacement: step 11, image 3 of 3
      • Run the opening pick and pry along the top seam.
      • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
      Ask FixBot
    6. Fairphone 1 Motherboard Replacement: step 12, image 1 of 1
      • Separate any remaining clips and remove the midframe from the phone.
      Ask FixBot
    1. Fairphone 1 Motherboard Replacement, Motherboard Assembly: step 13, image 1 of 3 Fairphone 1 Motherboard Replacement, Motherboard Assembly: step 13, image 2 of 3 Fairphone 1 Motherboard Replacement, Motherboard Assembly: step 13, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the volume rocker and power buttons from the display assembly.
      • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
      Ask FixBot
    2. Fairphone 1 Motherboard Replacement: step 14, image 1 of 1
      • Use the flat end of a spudger to disconnect the antenna cable connector.
      • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
      Ask FixBot
    3. Fairphone 1 Motherboard Replacement: step 15, image 1 of 2 Fairphone 1 Motherboard Replacement: step 15, image 2 of 2
      • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
      Ask FixBot
    4. Fairphone 1 Motherboard Replacement: step 16, image 1 of 3 Fairphone 1 Motherboard Replacement: step 16, image 2 of 3 Fairphone 1 Motherboard Replacement: step 16, image 3 of 3
      • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
      • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
      Ask FixBot
    5. Fairphone 1 Motherboard Replacement: step 17, image 1 of 1
      • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
      Ask FixBot
    6. Fairphone 1 Motherboard Replacement: step 18, image 1 of 2 Fairphone 1 Motherboard Replacement: step 18, image 2 of 2
      • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
      • Gently lift the top end of the motherboard up to expose the display data cable.
      • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
      Ask FixBot
    7. Fairphone 1 Motherboard Replacement: step 19, image 1 of 2 Fairphone 1 Motherboard Replacement: step 19, image 2 of 2
      • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
      Ask FixBot
    8. Fairphone 1 Motherboard Replacement: step 20, image 1 of 1
      • Remove the motherboard from the display assembly.
      Ask FixBot
    1. Fairphone 1 Motherboard Replacement, Rear Camera: step 21, image 1 of 3 Fairphone 1 Motherboard Replacement, Rear Camera: step 21, image 2 of 3 Fairphone 1 Motherboard Replacement, Rear Camera: step 21, image 3 of 3
      • Use the flat end of a spudger to disconnect the rear-facing camera cable connector from its socket on the motherboard.
      • Remove the rear facing camera from the motherboard.
      Ask FixBot
    1. Fairphone 1 Motherboard Replacement, Motherboard: step 22, image 1 of 1
      • Motherboard remains.
      • Remember to remove all the plastic seals of the new motherboard. You will find at least one covering the microphone for dust protection.
      Ask FixBot
8 other people completed this guide.
Andrew Optimus Goldheart
515,947 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
1 Guide Comment
This is a wonderful and detailed guide - thank you. However, I followed the instructions precisely and whilst the phone now switches on perfectly, the touchscreen does not work. Thoughts on how ifixthat welcome!!
Anthe George - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 122
All Time: 10,516
