Fahrenheit FHT 125PRMR Power Cord Replacement
    1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: step 1, image 1 of 1
      • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
      Ask FixBot
    2. Fahrenheit FHT 125PRMR Power Cord Replacement: step 2, image 1 of 1
      • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
      Ask FixBot
    3. Fahrenheit FHT 125PRMR Power Cord Replacement: step 3, image 1 of 2 Fahrenheit FHT 125PRMR Power Cord Replacement: step 3, image 2 of 2
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      Ask FixBot
    4. Fahrenheit FHT 125PRMR Power Cord Replacement: step 4, image 1 of 2 Fahrenheit FHT 125PRMR Power Cord Replacement: step 4, image 2 of 2
      • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
      • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
      Ask FixBot
    5. Fahrenheit FHT 125PRMR Power Cord Replacement: step 5, image 1 of 1
      • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
      Ask FixBot
4 other people completed this guide.
Joshua Potts
265 Reputation
1 Guide authored
IUPUI, Team 2-2, Harley Fall 2016 Member of IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Members
48 Guides authored
3 Guide Comments
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Reply Share
Where do you buy the power cord?
Dominique - Reply Share
probably available at electronic store
john john - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 51
All Time: 3,018
