Fahrenheit FHT 125PRMR Heating Plate Replacement
    1. Fahrenheit FHT 125PRMR Heating Plate Replacement, Heating Plate: step 1, image 1 of 1
      • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
      Ask FixBot
    2. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 2, image 1 of 1
      • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
      Ask FixBot
    3. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 3, image 1 of 2 Fahrenheit FHT 125PRMR Heating Plate Replacement: step 3, image 2 of 2
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      Ask FixBot
    4. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 4, image 1 of 1
      • Using Philips head (PH1) remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
      Ask FixBot
    5. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 5, image 1 of 1
      • Using Philips head (PH1) remove the two 4 mm silver screws on the sides of dial panel cover
      Ask FixBot
    6. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 6, image 1 of 2 Fahrenheit FHT 125PRMR Heating Plate Replacement: step 6, image 2 of 2
      • Using Philips head (PH00) to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
      Ask FixBot
    7. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 7, image 1 of 1
      • Remove the covering panel by pulling up with your hand.
      Ask FixBot
    8. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 8, image 1 of 1
      Ask FixBot
    9. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 9, image 1 of 2 Fahrenheit FHT 125PRMR Heating Plate Replacement: step 9, image 2 of 2
      • Remove 3 sliver screws (3mm) (PH1) from the motherboard.
      Ask FixBot
    10. Fahrenheit FHT 125PRMR Heating Plate Replacement: step 10, image 1 of 1
      Ask FixBot
Omar El Mounayri
61 Reputation
1 Guide authored
IUPUI, Team 2-2, Harley Fall 2016 Member of IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 36
All Time: 2,646
