Fahrenheit FHT 125PRMR Dial Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
94
All Time:
1,509
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help you replace a dial for a Fahrenheit FHT 125PRMR hair straightener that is not properly controlling the temperature of the device when powered on. Make sure the device is unplugged when working on it to avoid damaging any electrical components.
Tools
    1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: step 1, image 1 of 1
      • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
      Ask FixBot
    2. Fahrenheit FHT 125PRMR Dial Replacement: step 2, image 1 of 1
      • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
      Ask FixBot
    3. Fahrenheit FHT 125PRMR Dial Replacement: step 3, image 1 of 2 Fahrenheit FHT 125PRMR Dial Replacement: step 3, image 2 of 2
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      Ask FixBot
    4. Fahrenheit FHT 125PRMR Dial Replacement: step 4, image 1 of 2 Fahrenheit FHT 125PRMR Dial Replacement: step 4, image 2 of 2
      • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
      Ask FixBot
    5. Fahrenheit FHT 125PRMR Dial Replacement: step 5, image 1 of 1
      • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
      Ask FixBot
    6. Fahrenheit FHT 125PRMR Dial Replacement: step 6, image 1 of 2 Fahrenheit FHT 125PRMR Dial Replacement: step 6, image 2 of 2
      • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
      • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
      Ask FixBot
    7. Fahrenheit FHT 125PRMR Dial Replacement: step 7, image 1 of 1
      • Remove the covering panel by pulling up with your hand.
      Ask FixBot
    8. Fahrenheit FHT 125PRMR Dial Replacement: step 8, image 1 of 1
      Ask FixBot
Nicolas Moreau
180 Reputation
1 Guide authored
IUPUI, Team 2-2, Harley Fall 2016 Member of IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 94
All Time: 1,509
