FLSUN QQ Stepper Motor Damper Replacement
  1. FLSUN QQ Stepper Motor Damper Replacement, Power Down Printer: step 1, image 1 of 1
    • turn off power
    • unplug from wall
  2. FLSUN QQ Stepper Motor Damper Replacement, Open Base of Printer: step 2, image 1 of 1
    • Use 2.5mm hex key to remove 6 screws from base of printer
    • save screws for later
  3. FLSUN QQ Stepper Motor Damper Replacement, Identify Damaged Damper: step 3, image 1 of 1
    • visually inspect all dampers for damage
    • most likely damage is to the rubber section
  4. FLSUN QQ Stepper Motor Damper Replacement, Remove Tension from Belt: step 4, image 1 of 1
    • unscrew thumbscrew that tensions the belt
    • save thumbscrew for later
  5. FLSUN QQ Stepper Motor Damper Replacement, Remove Belt from Stepper Motor: step 5, image 1 of 2 FLSUN QQ Stepper Motor Damper Replacement, Remove Belt from Stepper Motor: step 5, image 2 of 2
    • use 2mm hex key to remove belt cover
    • remove belt from stepper motor
    • use 2.5mm hex key to remove stepper motor bracket from the top side
  6. FLSUN QQ Stepper Motor Damper Replacement, Remove Geared Pulley from Stepper Motor: step 6, image 1 of 1
    • measure the position of the geared pulley so that you can put it back later
    • use 2.5mm hex key to loosen set screws
    • slide geared pulley off of stepper motor shaft
  7. FLSUN QQ Stepper Motor Damper Replacement, Remove Motor Bracket: step 7, image 1 of 1
    • use hex key to remove last screw from the stepper motor mount
  8. FLSUN QQ Stepper Motor Damper Replacement, Replace Damaged Damper: step 8, image 1 of 3 FLSUN QQ Stepper Motor Damper Replacement, Replace Damaged Damper: step 8, image 2 of 3 FLSUN QQ Stepper Motor Damper Replacement, Replace Damaged Damper: step 8, image 3 of 3
    • use hex key to remove 2 screws holding the damper to the stepper motor
    • use Phillips #1 to install new damper
    • alternatively, use hex key to install new damper with old screws
  9. FLSUN QQ Stepper Motor Damper Replacement, Re-Install Stepper Motor: step 9, image 1 of 2 FLSUN QQ Stepper Motor Damper Replacement, Re-Install Stepper Motor: step 9, image 2 of 2
    • re-attach geared pulley
    • re-attach stepper motor mount/bracket to the damper
    • Remember the screws you saved when removing the motor mount?
    • re-attach stepper motor bracket with screws from above
    • re-install pulley / tensioner to top of frame with thumb screw
    • re-tension belt
    • finally re-install the belt cover
    • Some people have suggested that this belt cover is not needed. It is possible that you could re assemble with one of the screws left over from replacing the damper to secure the damper to the mount.
To reassemble your device, follow these instructions in reverse order. If you have no screws left over, you win!
Daniel Green
1,161 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 1,070
