FLSUN QQ Stepper Driver Replacement (TMC2208)
    • Power Off Printer
    • Unplug Printer From Outlet
    Ask FixBot
  1. FLSUN QQ Stepper Driver Replacement (TMC2208), Open Base of Printer: step 2, image 1 of 1
    • Use 2.5mm Hex Driver
    • Remove 6 Screws from Base of Printer
    • Carefully remove cover.
    Ask FixBot
  2. FLSUN QQ Stepper Driver Replacement (TMC2208), Remove Old Stepper Driver: step 3, image 1 of 1
    • Unplug Stepper Cable
    • Gently Remove Stepper Driver
    Ask FixBot
    • You can skip this step if you reverse the direction of the steppers in firmware.
    • Using small needle nose pliers gently remove the plastic clip that holds the stepper cable connector.
    • Alternate pulling from the top and bottom of the clip to avoid damage to the board.
    • Rotate the plastic clip 180º
    • Gently, but firmly, press the plastic clip back onto the board.
    Ask FixBot
  3. FLSUN QQ Stepper Driver Replacement (TMC2208), Plug In the New TMC2208 Driver: step 5, image 1 of 1
    • Align the pins in the correct location and position.
    • In my case the blue header on the TMC2208 aligned with the green side of the socket on the board.
    • Press gently but firmly into place.
    Ask FixBot
  4. FLSUN QQ Stepper Driver Replacement (TMC2208), Install Heat Sink: step 6, image 1 of 3 FLSUN QQ Stepper Driver Replacement (TMC2208), Install Heat Sink: step 6, image 2 of 3 FLSUN QQ Stepper Driver Replacement (TMC2208), Install Heat Sink: step 6, image 3 of 3
    • Avoid shorting out any of the pins. Do not place heat sink in contact with any of the pins.
    • Remove sticker from back of heat sink
    • Carefully press the heat sink to the back of the TMC2208
    Ask FixBot
    • Remove Old Driver
    • Reverse Direction of Stepper
    • Insert TMC2208
    • Add Heatsink
    • Plug Stepper Back In
    Ask FixBot
Re-assemble your printer and enjoy near silent (fans make some noise) printing!
2 other people completed this guide.
Daniel Green
1,161 Reputation
6 Guides authored
8 Guide Comments
How about Vref?
wmenant - Reply Share
I haven't needed to mess with it.
Daniel Green - Reply Share
Hi, thanks for a great tutorial!
Does the firmware of the QQ-S need to be updated/replaced as well, or will these drivers run with stock FW?
Thanks again!
RJ T - Reply Share
You can either, flip the orientation of the plug on the board, or modify config values in the firmware config file and re-flash the firmware. I chose to flip the plug so I would need to mess with flashing firmware.
Do you need to reverse the plug for a 2209? Difference between 2208 and 2209 for my QQS Pro?
Alex Smith - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 60
All Time: 6,456
