FIAT 500 Low Beam Bulb Replacement
Views: 39K
View statistics:
Past 24 Hours:
30
Past 7 Days:
272
Past 30 Days:
1,052
All Time:
38,958
Comments: 3
3 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
For your safety and that of other drivers, it is important to quickly replace a dipped headlight bulb.
The model shown is a FIAT 500 III 1.2, but this should be similar for all FIAT 500s.
    1. FIAT 500 Low Beam Bulb Replacement, Low Beam Bulb: step 1, image 1 of 3 FIAT 500 Low Beam Bulb Replacement, Low Beam Bulb: step 1, image 2 of 3 FIAT 500 Low Beam Bulb Replacement, Low Beam Bulb: step 1, image 3 of 3
      • Apply the handbrake and remove the keys, then open the hood.
      Ask FixBot
    2. FIAT 500 Low Beam Bulb Replacement: step 2, image 1 of 2 FIAT 500 Low Beam Bulb Replacement: step 2, image 2 of 2
      • Remove the cover by pulling on the tip.
      • The cover is easy to remove, but take a good look at how it is secured so it can be reinstalled in the same orientation
      Ask FixBot
    3. FIAT 500 Low Beam Bulb Replacement: step 3, image 1 of 3 FIAT 500 Low Beam Bulb Replacement: step 3, image 2 of 3 FIAT 500 Low Beam Bulb Replacement: step 3, image 3 of 3
      • Pinch and hold the bulb holder by its release tab and remove the holder and bulb from its housing.
      • Do this slowly; during reassembly you will have to put it back in the same position correctly.
      • While it's not important for a bulb you're going to dispose of, for new bulbs or a bulb you're going to reuse do not touch the glass with your bare hands. Oil from your skin can collect heat and result in failure of the glass envelope. If you do touch it by accident, clean it thoroughly with isopropyl alcohol.
      Ask FixBot
    4. FIAT 500 Low Beam Bulb Replacement: step 4, image 1 of 2 FIAT 500 Low Beam Bulb Replacement: step 4, image 2 of 2
      • Hold the plastic bulb holder with one hand and remove the bulb by grasping it by the metal edges. Rock it back and forth to remove it.
      Ask FixBot
    5. FIAT 500 Low Beam Bulb Replacement: step 5, image 1 of 1
      • Replace the defective bulb with the same model, here H7 12V 55W.
      Ask FixBot
To reassemble your headlight, follow the instructions in reverse order.
7 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
huby
1,703 Reputation
1 Guide authored
3 Guide Comments
Bonsoir.......pourquoi toujours montrer le remplacement sur le phare droit? Juste pour rire, remplacer l'ampoule de code sur le phare gauche avec la traverse, la batterie et la boîte a fusible..........j'ai dû le faire et je vous promet que j'aurai mis avec un immense plaisir, des grandes claques dans la gueule des ingénieurs ! Il faut avoir une main d'un enfant de 5ans avec des doigts de pianiste avec une dextérité de gynéco et une patiente d'ange. Curieux de voir un tuto "facile".
Frederic Guy - Reply Share
C'est pas faux ! 😂
R B - Reply Share
Bravo ,Meilleur explications les autres à part voir des grosses mains qui cachent tout on ne voit pas grand chose .merci
Jean-louis Careddu - Reply Share
Past 24 Hours: 30
Past 7 Days: 272
Past 30 Days: 1,052
All Time: 38,958
