Up to 20% off select tools
FDHD Floppy drive Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
77
All Time:
601
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Hello this is actually a cleaning for an FDHD Drive but since they didn’t have an option for cleaning I picked disassembly.
    1. FDHD Floppy drive Disassembly, Step 1 pull off the springs: step 1, image 1 of 1
      • It’s best to pull Down and twist to pull the spring off
      Ask FixBot
    2. FDHD Floppy drive Disassembly, Pull the other spring off: step 2, image 1 of 1
      • Once again pull and twist movement
      Ask FixBot
    3. FDHD Floppy drive Disassembly, Move this black tab off: step 3, image 1 of 1
      • lift up on the really tiny tab with a flat blade screwdriver and slide it off
      Ask FixBot
      • Push Down
      Ask FixBot
      • It may seem a little bit tricky at first but only push the ejection lever about halfway in
      Ask FixBot
    4. FDHD Floppy drive Disassembly, Unscrew motor: step 6, image 1 of 1
      • Remove these two screws and lift off the motor
      • Note: I did not have the second screw.
      Ask FixBot
    5. FDHD Floppy drive Disassembly, Lift off motor: step 7, image 1 of 1
      • Unplug the motors 3-pin connector to make it easier
      Ask FixBot
    6. FDHD Floppy drive Disassembly, Take off the tiny black washers: step 8, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
      Ask FixBot
      • Thank you for using my guide just clean any places where metal touches metal and reassemble
      Ask FixBot
Author
with
Timmytheterror
671 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 77
All Time: 601
