Up to 20% off select tools
F. PanelDue Firmware Update
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
79
All Time:
2,262
Comments: 0
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Instructions for updating the PanelDue firmware can also be found here
    1. F. PanelDue Firmware Update, Downloads: step 1, image 1 of 1
      • Download the latest stable firmware from the Duet Github and extract the zip file
      • Make sure you download the correct version. The PanelDue 5i and 7i both use the same firmware binary. The file you want is named "PanelDue-5.0i-7.0i.bin"
      • FYSETC documentation says to use the 5i/7i combined binary("PanelDue-5.0i-7.0i.bin") for their 5i and 7i screens. If you use the combined version for you FYSETC 5i/7i your color scheme will be incorrect.
      • You need to install "PanelDueFirmware-v3-7.0.zip" or "PanelDueFirmware-v3-5.0.zip"
      • Download and install Bossa
      Ask FixBot
    2. F. PanelDue Firmware Update, Connecting to your PC: step 2, image 1 of 1
      • Hold the erase button on the back of the PanelDue
      • Connect a USB Micro cable from your PC to your PanelDue. Release the erase button and press the reset button.
      • Identify the COM port the PanelDue is using.
      • Click Start->Control Panel->System->Device Manager. Expand Ports (COM and LPT)
      Ask FixBot
    3. F. PanelDue Firmware Update, Flashing the Firmware: step 3, image 1 of 1
      • Once connected open Bossa.
      • Select the port in the dropdown. Click Browse and select the PanelDue firmware
      • Select the checkboxes for Erase all, Lock, and Boot from flash
      • Click Write. Bossa will load the firmware to the PanelDue. Once upload is complete, click Verify.
      Ask FixBot
Finish Line
8 other people completed this guide.
Author
with
David Husolo
9,382 Reputation
33 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 79
All Time: 2,262
