Up to 20% off select tools
Eyeglasses Spring Hinge Screw Replacement
Views: 289K
View statistics:
Past 24 Hours:
52
Past 7 Days:
286
Past 30 Days:
1,278
All Time:
289,302
Comments: 39
6 comments on steps, 33 guide comments.
Go to guide comments
Completed: 60
60 people have marked this guide "completed." Will you be next?
Favorites: 69
69 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This repair video served as the inspiration for my guide. A big thanks to danliv99 from YouTube for helping me fix my glasses!
    1. Eyeglasses Spring Hinge Screw Replacement, Spring Hinge Screw: step 1, image 1 of 1
      • These are the tools I used to insert the screw through the spring hinge. In the video a paperclip was used, but the paperclip I had on-hand could not fit into the tiny recess in order to jam the spring open.
      Ask FixBot
    2. Eyeglasses Spring Hinge Screw Replacement: step 2, image 1 of 1
      • The problem at hand: The screw will not fit through the arm because a spring is pulling on the hinge (and screw hole) in the arm.
      Ask FixBot
    3. Eyeglasses Spring Hinge Screw Replacement: step 3, image 1 of 1
      • Insert a pushpin through the hole and use it as leverage to extend the spring hinge outwards.
      Ask FixBot
    4. Eyeglasses Spring Hinge Screw Replacement: step 4, image 1 of 2 Eyeglasses Spring Hinge Screw Replacement: step 4, image 2 of 2
      • Be careful not to push the pushpin into your finger, as opposed to the small notch that you've just uncovered.
      • Once the spring hinge extends outward with the first pushpin, use a second pushpin to keep the hole in the "extended" position:
      • There will be a small notch revealed once the spring hinge extends outwards. Wedge the second pushpin into that notch so that the hinge doesn't go back inwards.
      • I sadly only have two hands, so I was not able to show how to wedge the pushpin and take the photo.
      Ask FixBot
    5. Eyeglasses Spring Hinge Screw Replacement: step 5, image 1 of 2 Eyeglasses Spring Hinge Screw Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • With the second pushpin hanging around, line up the eyeglass frame/arm holes together.
      • Use a pair of tweezers to insert your eyeglass screw through both holes.
      Ask FixBot
    6. Eyeglasses Spring Hinge Screw Replacement: step 6, image 1 of 2 Eyeglasses Spring Hinge Screw Replacement: step 6, image 2 of 2
      • Finally, use a 1.2 mm flat-blade screwdriver to secure the arm to the frame.
      • Presto-blamo! Your eyeglasses are fixed.
      • The same procedure can be used on sunglasses without any problems.
      Ask FixBot
60 other people completed this guide.
Author
with
33 Guide Comments
Nice guide. Simple, straight forward and it works. In my experience I used a standard tack because that's all I had. I was able to hold pressure on the tack while I set the arm in place. Worked like a charm.
mtscott - Reply Share
Thanks for this, the screw came out on my glasses and I'm new to glasses so had no idea how to get the screw back in, thanks again! Saved my life on Xmas eve as I was about to leave my house to head to see my family.
Jake - Reply Share
Excellent process and photos! I couldn't get a push pin to stay in the gap of my foster grant readers, but used another tiny screwdriver instead. Same idea, slightly different tool. Thanks!
Tom S - Reply Share
It's kind of confusing. Is there any other simpler explanation?
Carissa Mcellan - Reply Share
Thank you. Much appreciated
Steve White - Reply Share
Past 24 Hours: 52
Past 7 Days: 286
Past 30 Days: 1,278
All Time: 289,302
