Up to 20% off select tools
ExoPC Slate Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
62
All Time:
730
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing the camera on the ExoPC Slate is simple; however, be sure to remove components gently and keep track of them.
    1. ExoPC Slate Camera Replacement, Camera: step 1, image 1 of 1
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      Ask FixBot
    2. ExoPC Slate Camera Replacement: step 2, image 1 of 1
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      Ask FixBot
    3. ExoPC Slate Camera Replacement: step 3, image 1 of 1
      • Remove the tape covering the metal shield.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      Ask FixBot
    4. ExoPC Slate Camera Replacement: step 4, image 1 of 2 ExoPC Slate Camera Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to disconnect camera cable from motherboard.
      • Remove the Phillips #000 screw that holds the camera in place.
      • Gently remove the camera.
      Ask FixBot
Author
with
Aaron Moore
217 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 62
All Time: 730
