Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
High Content Rubbing Alcohol$12.99
Tools
Introduction
Go to step 1 ↓The fan and heat sink are components that prevent the device from overheating. The heat sink is usually made out of a thermal conducting metal such as copper or aluminum. Internally the fan has ball bearing that rotate and reduce friction. Over time these ball bearings can fail causing noise and eventual cause the fan to stop working.
Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
Using the 00 Phillips screwdriver remove the two screws in the corners.
Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
Remove the yellow tape securing the wires to the PCB board as well as the silver/grey tape.
Unscrew the six Phillips #00 screws.
