Up to 20% off select tools
Evercade EXP Screen Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
107
All Time:
374
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your Evercade EXP (model FG-HHEX-HHC-USA) screen is cracked, unresponsive, displaying visual glitches, or not turning on at all, the display assembly may need to be replaced. This guide will walk you through the process of safely removing and replacing the screen.
Before starting, power off the device completely and disconnect it from any charging cables. You will need to work carefully, as the screen and its connecting cables are fragile and can be easily damaged if handled improperly. It is recommended to use proper tools and avoid excessive force when opening the device.
Take caution when separating the screen from the body, as adhesive may be present and delicate ribbon cables connect the display to the motherboard. Damaging these components can make the device unusable.
If you are unsure whether the screen is the issue, try troubleshooting first—such as restarting the device or checking for external damage—before proceeding with replacement.
    1. Evercade EXP Screen Replacement, Faceplate: step 1, image 1 of 3 Evercade EXP Screen Replacement, Faceplate: step 1, image 2 of 3 Evercade EXP Screen Replacement, Faceplate: step 1, image 3 of 3
      • Lay the device on a flat surface, with the screen facing the sufrace.
      • Using angled tweezers, remove the six rubber screw covers from the sockets.
      • The covers are all identical, so they do not need to be stored separately from one another.
      Ask FixBot
    2. Evercade EXP Screen Replacement: step 2, image 1 of 3 Evercade EXP Screen Replacement: step 2, image 2 of 3 Evercade EXP Screen Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
      Ask FixBot
    3. Evercade EXP Screen Replacement: step 3, image 1 of 2 Evercade EXP Screen Replacement: step 3, image 2 of 2
      • Flip the device so the screen is facing you.
      • Four hidden retaining clips hold the pieces together even near each corner of the screen.
      • Insert a Jimmy into the seam located between the faceplate and the shell.
      • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
      • Repeat until for each of the four clasps to fully release the faceplate from the shell.
      • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
      Ask FixBot
    4. Evercade EXP Screen Replacement: step 4, image 1 of 3 Evercade EXP Screen Replacement: step 4, image 2 of 3 Evercade EXP Screen Replacement: step 4, image 3 of 3
      • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
      • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
      • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
      Ask FixBot
    1. Evercade EXP Screen Replacement, Screen: step 5, image 1 of 3 Evercade EXP Screen Replacement, Screen: step 5, image 2 of 3 Evercade EXP Screen Replacement, Screen: step 5, image 3 of 3
      • The screen is attached with a double-sided adhesive. When removing the screen make sure the work area is clean to prevent smudges on the interior of the screen.
      • To remove the display from the screen, insert a spudger into the gap between the screen and display at the corner.
      • Slowly move the spudger along the seam until you reach the opposite corner.
      • Use your hand to gently pull the screen away from the display which will break the adhesive seal.
      • Be careful when removing the display because it is fragile that metal tools will easily crack or scratch the glass.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Ariana Travis
295 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 107
All Time: 374
