Up to 20% off select tools
Evercade EXP Faceplate Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
15
Past 30 Days:
87
All Time:
378
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the faceplate of your Evercade EXP is cracked, damaged, or dirty, use this guide to replace it.
The faceplate is the first line of defense of the console. It shields the delicate internal components from basic damage like dust, water, and impact.
Before beginning the repair, inspect the faceplate and shell for cosmetic damage that may compromise the mechanism holding the faceplate to the shell, as damage may make disassembly more difficult.
Power the device off completely and ensure it is disconnected from any power source before beginning.
    1. Evercade EXP Faceplate Replacement, Faceplate: step 1, image 1 of 3 Evercade EXP Faceplate Replacement, Faceplate: step 1, image 2 of 3 Evercade EXP Faceplate Replacement, Faceplate: step 1, image 3 of 3
      • Lay the device on a flat surface, with the screen facing the sufrace.
      • Using angled tweezers, remove the six rubber screw covers from the sockets.
      • The covers are all identical, so they do not need to be stored separately from one another.
      Ask FixBot
    2. Evercade EXP Faceplate Replacement: step 2, image 1 of 3 Evercade EXP Faceplate Replacement: step 2, image 2 of 3 Evercade EXP Faceplate Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
      Ask FixBot
    3. Evercade EXP Faceplate Replacement: step 3, image 1 of 2 Evercade EXP Faceplate Replacement: step 3, image 2 of 2
      • Flip the device so the screen is facing you.
      • Four hidden retaining clips hold the pieces together even near each corner of the screen.
      • Insert a Jimmy into the seam located between the faceplate and the shell.
      • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
      • Repeat until for each of the four clasps to fully release the faceplate from the shell.
      • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
      Ask FixBot
    4. Evercade EXP Faceplate Replacement: step 4, image 1 of 3 Evercade EXP Faceplate Replacement: step 4, image 2 of 3 Evercade EXP Faceplate Replacement: step 4, image 3 of 3
      • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
      • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
      • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Michael Williams
356 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 87
All Time: 378
