Up to 20% off select tools
Evercade EXP Battery Replacement
Views: 1K
View statistics:
Past 24 Hours:
7
Past 7 Days:
47
Past 30 Days:
221
All Time:
1,036
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If your Evercade EXP (model FG-HHEX-HHC-USA) is no longer holding a charge, powering on intermittently, or shutting down unexpectedly, the internal battery may be worn out or faulty. This guide will walk you through the steps required to safely remove and replace the battery in your device.
Before beginning, make sure the device is powered off and disconnected from any charging cables. Ensure the work environment is a clean, static-free environment and use the proper tools to avoid damaging internal components. Be cautious when handling the battery, as puncturing or bending it can be hazardous.
If you are unsure whether the battery is the issue, consider checking basic troubleshooting steps such as trying a different charging cable or power source before proceeding with replacement.
    1. Evercade EXP Battery Replacement, Faceplate: step 1, image 1 of 3 Evercade EXP Battery Replacement, Faceplate: step 1, image 2 of 3 Evercade EXP Battery Replacement, Faceplate: step 1, image 3 of 3
      • Lay the device on a flat surface, with the screen facing the sufrace.
      • Using angled tweezers, remove the six rubber screw covers from the sockets.
      • The covers are all identical, so they do not need to be stored separately from one another.
      Ask FixBot
    2. Evercade EXP Battery Replacement: step 2, image 1 of 3 Evercade EXP Battery Replacement: step 2, image 2 of 3 Evercade EXP Battery Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
      Ask FixBot
    3. Evercade EXP Battery Replacement: step 3, image 1 of 2 Evercade EXP Battery Replacement: step 3, image 2 of 2
      • Flip the device so the screen is facing you.
      • Four hidden retaining clips hold the pieces together even near each corner of the screen.
      • Insert a Jimmy into the seam located between the faceplate and the shell.
      • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
      • Repeat until for each of the four clasps to fully release the faceplate from the shell.
      • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
      Ask FixBot
    4. Evercade EXP Battery Replacement: step 4, image 1 of 3 Evercade EXP Battery Replacement: step 4, image 2 of 3 Evercade EXP Battery Replacement: step 4, image 3 of 3
      • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
      • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
      • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
      Ask FixBot
    1. Evercade EXP Battery Replacement, Motherboard: step 5, image 1 of 3 Evercade EXP Battery Replacement, Motherboard: step 5, image 2 of 3 Evercade EXP Battery Replacement, Motherboard: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove all ten 8 mm screws securing the motherboard.
      Ask FixBot
    2. Evercade EXP Battery Replacement: step 6, image 1 of 1
      • Using angled tweezers, gently lift both speakers from the cavities they rest in.
      • Don't attempt to fully remove the speakers from the motherboard. They're still secured with soldered connections.
      • The speakers are held in place by a weak adhesive. Apply force when removing speakers. Be careful not to damage the surrounding frame and speakers.
      Ask FixBot
    3. Evercade EXP Battery Replacement: step 7, image 1 of 3 Evercade EXP Battery Replacement: step 7, image 2 of 3 Evercade EXP Battery Replacement: step 7, image 3 of 3
      • The battery is wired to the motherboard via a connector inserted into a socket.
      • Flip the motherboard to the outside of the console.
      • The side boards are connected to the center board by a ribbon cable and a soldered wire, when removing the entire motherboard, keep them connected.
      • Remove the connector from the socket attached to the motherboard. The piece is held in place near the back of the socket. Apply downward pressure while pulling out to make the removal easier.
      • When removing the connector, it may require a significant amount of force. If too much force is applied, the plastic connector may compress or snap.
      Ask FixBot
    1. Evercade EXP Battery Replacement, Battery: step 8, image 1 of 3 Evercade EXP Battery Replacement, Battery: step 8, image 2 of 3 Evercade EXP Battery Replacement, Battery: step 8, image 3 of 3
      • The battery is connected to the case with a strong adhesive. To remove the battery, you will need to use a heat source to loosen then adhesive.
      • Use a hair dryer or a heat gun on low to apply heat to the back of the case while gently prying the battery out with an opening tool.
      • Take care not to bend, warp, twist, or puncture the battery during removal. Avoid using tweezers or metal pry tools to remove batteries unless absolutely necessary. Metal tools can easily puncture batteries and cause the release of noxious chemicals or even start a fire.
      • Set the battery aside for recycling.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Ariana Travis
295 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 47
Past 30 Days: 221
All Time: 1,036
