Up to 20% off select tools
Eureka EasyClean 71C Casing Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
99
All Time:
1,097
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
Some vital parts of the vacuum cleaner require you to remove the casing in order to replace them. This guide serves as a prerequisite only to the guides on how to replace those parts.
    1. Eureka EasyClean 71C Casing Replacement, Bottom Cover: step 1, image 1 of 1
      • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
      Ask FixBot
    2. Eureka EasyClean 71C Casing Replacement: step 2, image 1 of 1
      • Pry off the Riser Visor using the plastic opening tool.
      Ask FixBot
    3. Eureka EasyClean 71C Casing Replacement: step 3, image 1 of 1
      • Remove the screw cap using the metal spudger.
      • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
      Ask FixBot
    4. Eureka EasyClean 71C Casing Replacement: step 4, image 1 of 2 Eureka EasyClean 71C Casing Replacement: step 4, image 2 of 2
      • Unscrew the 14mm PH2 Phillips head screw.
      • Pull the bottom cover off of the rest of the casing.
      Ask FixBot
    1. Eureka EasyClean 71C Casing Replacement, Casing: step 5, image 1 of 1
      • Pull the power switch all the way up and remove the dust cup.
      Ask FixBot
    2. Eureka EasyClean 71C Casing Replacement: step 6, image 1 of 2 Eureka EasyClean 71C Casing Replacement: step 6, image 2 of 2
      • Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
      • Pull the casing apart.
      Ask FixBot
Author
with
Tanner Durnil
631 Reputation
6 Guides authored
IUPUI, Team S6-G4, Baechle Fall 2017 Member of IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 99
All Time: 1,097
