Eureka EasyClean 71C Belt Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
85
All Time:
2,237
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Sometimes, the belt in the vacuum can go bad or even just come loose. In order to properly maintain your vacuum, it’s important to know how to replace the belt. This guide covers the necessary steps for a successful replacement. Make sure your vacuum is off before attempting any replacements.
Tools
    1. Eureka EasyClean 71C Belt Replacement, Bottom Cover: step 1, image 1 of 1
      • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
      Ask FixBot
    2. Eureka EasyClean 71C Belt Replacement: step 2, image 1 of 1
      • Pry off the Riser Visor using the plastic opening tool.
      Ask FixBot
    3. Eureka EasyClean 71C Belt Replacement: step 3, image 1 of 1
      • Remove the screw cap using the metal spudger.
      • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
      Ask FixBot
    4. Eureka EasyClean 71C Belt Replacement: step 4, image 1 of 2 Eureka EasyClean 71C Belt Replacement: step 4, image 2 of 2
      • Unscrew the 14mm PH2 Phillips head screw.
      • Pull the bottom cover off of the rest of the casing.
      Ask FixBot
    1. Eureka EasyClean 71C Belt Replacement, Belt: step 5, image 1 of 2 Eureka EasyClean 71C Belt Replacement, Belt: step 5, image 2 of 2
      • Pull the roller, motor, and belt out of the casing.
      • Separate the belt from both the roller and the motor.
      Ask FixBot
Tanner Durnil
631 Reputation
6 Guides authored
IUPUI, Team S6-G4, Baechle Fall 2017 Member of IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Members
72 Guides authored
1 Guide Comment
Hello would you know what belt number this would use? I have looked everywhere. I would appreciate it
vdean4b - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 85
All Time: 2,237
