Up to 20% off select tools
Eureka 1660SP External Start Switch Realignment
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
90
All Time:
3,067
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Eureka 1660SP External Start Switch Realignment, Motor Housing: step 1, image 1 of 2 Eureka 1660SP External Start Switch Realignment, Motor Housing: step 1, image 2 of 2
      • Before you start, make sure your vacuum is unplugged the power outlet.
      • Press and hold down the black button below the handle while pulling the pole out.
      Ask FixBot
    2. Eureka 1660SP External Start Switch Realignment: step 2, image 1 of 2 Eureka 1660SP External Start Switch Realignment: step 2, image 2 of 2
      • Press the black separator switch to separate the top and bottom halves of the vacuum.
      Ask FixBot
    3. Eureka 1660SP External Start Switch Realignment: step 3, image 1 of 3 Eureka 1660SP External Start Switch Realignment: step 3, image 2 of 3 Eureka 1660SP External Start Switch Realignment: step 3, image 3 of 3
      • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
      • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
      • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
      Ask FixBot
    1. Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: step 4, image 1 of 3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: step 4, image 2 of 3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: step 4, image 3 of 3
      • If the external switch is slightly misaligned as shown, realign it with the internal switch.
      • Make sure the spring loaded button on the underside of the housing is intact when reassembling the motor housing. It is prone to eject when opening the motor housing.
      Ask FixBot
Author
with
Evan Fodi
122 Reputation
2 Guides authored
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 90
All Time: 3,067
