Euhomy IM-06D Power Supply Cable Replacement
  1. Euhomy IM-06D Power Supply Cable Replacement, Fan: step 1, image 1 of 1
    • Rotate the device so that the screws on the bottom are visible.
    • Remove the two 15 mm Phillips screws.
    • Remove the two 10 mm Phillips screws.
    Ask FixBot
  2. Euhomy IM-06D Power Supply Cable Replacement: step 2, image 1 of 2 Euhomy IM-06D Power Supply Cable Replacement: step 2, image 2 of 2
    • Remove the back panel from the device.
    Ask FixBot
  3. Euhomy IM-06D Power Supply Cable Replacement: step 3, image 1 of 1
    • Remove the two 10 mm Phillips screws that secure the fan.
    Ask FixBot
  4. Euhomy IM-06D Power Supply Cable Replacement: step 4, image 1 of 2 Euhomy IM-06D Power Supply Cable Replacement: step 4, image 2 of 2
    • Remove the cover plate.
    Ask FixBot
  5. Euhomy IM-06D Power Supply Cable Replacement: step 5, image 1 of 2 Euhomy IM-06D Power Supply Cable Replacement: step 5, image 2 of 2
    • Snip the zip tie holding the wires together.
    • Unplug the wire from the board.
    • Remove the fan from the device.
    Ask FixBot
  6. Euhomy IM-06D Power Supply Cable Replacement, Power Supply Cable: step 6, image 1 of 1
    • Follow the green ground wire and remove the 15 mm screw securing it with a Phillips screwdriver.
    Ask FixBot
  7. Euhomy IM-06D Power Supply Cable Replacement: step 7, image 1 of 2 Euhomy IM-06D Power Supply Cable Replacement: step 7, image 2 of 2
    • Remove the Phillips screw holding the power cable in place.
    Ask FixBot
  8. Euhomy IM-06D Power Supply Cable Replacement: step 8, image 1 of 2 Euhomy IM-06D Power Supply Cable Replacement: step 8, image 2 of 2
    • Follow the white wire and unplug it from the motherboard.
    • Follow the black wire and disconnect it from the motherboard.
    • Remove the power supply cable.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Joel Mello
415 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 37
All Time: 206
